Need help re: replacing engine air filters
I've never changed an engine air filter in my life, but I hear they are quite easy to replace on the G37 Sedan.
Can anyone point me to a service bulletin or post some photos with instructions?
No rush - I'm SEVERAL months out from replacing OEM.
Many thanks.
PS I will be using two Wix 49382 filters for the job.
PPS Many thanks to Redline37 for posting the cabin air filter procedure. I'll be using Wix Part #24479 for the cabin filter change when the time comes.
Many thanks.
Check the owner's manual. Illustrations and written instructions. Then you'll already have a copy printed out with the car when you're in the process!
On mine (2009) it's page 8-18. In the "Maintenance and Do-It-Yourself" chapter, under "Air cleaner."
Hope that helps!
Hope that helps!
Apologies if that was a typo, but according to the Wix site that should be 49362. The 49382 is a BMW cabin filter.
WIX Filters : Filter Look-Up
Yes it was a typo. I ordered the right part.
PS Thanks SM for the heads up re: owners' manual.
superjoey
31
03-22-2023 11:56 PM
