Anyone Actually Install OEM Spoiler?
Can't seem to find any posts from someone who installed the OEM spoiler themselves. Mine will be arriving in a few days and I'm really comtemplating doing this myself. I'm handy and know my way around the tool box. I know I want to get some new, sharp drill bits as mine have seen better days,
If anyone has done this, please comment. Hard/Easy, Gottcha's? I bought touch up paint and plan to paint any exposed metal caused by drilling and use silicone to help seal against leaks.
Actually I have one of those already. When you drill in metal you should use a set tap to make a small starter indentation then start with smaller drills and work your way up. Do you remember what the final hole size is?
What did you do about the rear deck and the back window break light? Oh, and thanks for responding BTW. I'm about 99.9% convinced to do it myself and save a few hundred bucks.
I assume it also uses double sided tape for the install. Do you know if your friend can handle the touchless car washes that use the big blowers at the end to dry the car? I see they have a warning at the car wash.
thanks man!
SpeedBallDEVIL
08-12-2015 04:30 PM
