DIY: 2010 G37s Reverse Shift Direction Wire Colors
I have found several threads on how to do this (pull back to shift up, push forward to shift down), but want to be sure of the wire colors first before I do mine. Thanks in advance.
G-DOG
I just checked the wiring diagrams in the 2010 G37 sedan service manual and it shows the same wires that are switched for the 5AT (violet [pin 2] and blue [pin 3]) need to be switched for the 7AT as well.
The attached diagram shows the location of these two wires in the connector.
See this thread for more information on how to access the connector:
https://www.myg37.com/forums/d-i-y-i...n-for-5at.html
maybeg37
09-08-2015 02:33 PM
