Installing springs(question)
Old 02-23-2010, 02:09 PM
Jakex1
Jakex1's Avatar
a shop by my house said hes charging 300$ for installing 4 springs. i've heard that with a second set of hands its not too bad to DIY.
Thoughts? and if i diy, how would i get access to the bolts holding in the rear shocks?
Old 02-23-2010, 04:57 PM
hispeed-lowdrag
hispeed-lowdrag's Avatar
IMHO I wouldn't DIY just b/c there is stuff that can go really wrong. If you know what you are doing, then I would think you'd be ok, I just get nervous around suspensions.
$300 seems super expensive...I got mine installed for $145 for all 4 Eibach PK.
Old 02-23-2010, 05:19 PM
Jakex1
Jakex1's Avatar
145$ is something i wouldnt mind paying.... anyone know a place in NY?
Old 02-23-2010, 05:31 PM
SoFloG37
SoFloG37's Avatar
i did it my self 4 times, lol the first time i did it by just looking and taking stuff apart lol but there is a DIY on here somewhere, if not check 370z forum
Old 02-23-2010, 05:34 PM
Jakex1
Jakex1's Avatar
i saw youtube for the videos, seemed fairly simple. lift car, take off wheel, take off struts, use the spring compressor or w.e, take out spring, put new one in, have someone push it down while you screw it back on, reverse steps.
Old 02-23-2010, 05:58 PM
wakeboardr116
wakeboardr116's Avatar
Pay someone. 300 is way too much though. There is one bolt on the front struts that is very difficult to get off and can risk stipping it (happened to me). Then if you are doing Eibach springs conventional spring compressors from autozone etc. will not work. Atleast none of the ones I rented would. The top of the eibachs is too narrow to get the spring compressor in.
Old 02-23-2010, 06:03 PM
RaulGCustom
SoCal Driven
RaulGCustom's Avatar
I did it myself, fairly easy. I have coilovers, so it was easier to just take the whole spring and shock together. As far as the rear bolts, you can access them by just simply unscrewing the two top screws that hold it in place. Meaning, you dont have to take the interior apart, you can see them by just looking up at the shock, you'll see the two bolts.
Old 02-23-2010, 07:38 PM
Jakex1
Jakex1's Avatar
thanks for the input guys. Any idea where i can get them installed in NY? more specifically the L.I. area?
Old 02-23-2010, 09:29 PM
Weiboy718
Weiboy718's Avatar
if you're just installing springs, you don't need to remove the rear shocks!
the front is a whole different game though. you really gotta know what you doing or else you'll get stuck and mess something up.
here's a short write up for removing the rear springs. let me know if you need instructions for the fronts.
tools needed for the rears to remove the spring:
size: 17mm socket, ratchet and wrench. only 1 nut and bolt holding on to the spring perch. have a hydraulic jack and slide it under the spring perch to prevent it from falling after you remove the nut and bolt. when the bolt is out slowly let down of your jack and the perch is slanted down, you can either use your foot and hands to hold it down and remove the spring. it's very simple.
to install it back you just reverse the process by putting the springs back onto the perch and then slide your jack underneath the perch to lift it back up and be sure to align the holes before you try to jam the bolt back in. don't ever jam it in cuz the bolt itself is threaded.
Old 02-23-2010, 10:07 PM
Mysticalism
Mysticalism's Avatar
the shop that will do it for me charges $100 CAD lol
Old 02-23-2010, 10:08 PM
Mysticalism
but then, i know the guy
Old 02-24-2010, 01:36 PM
Jakex1
Jakex1's Avatar
Old 02-24-2010, 02:14 PM
marcelo19lp
marcelo19lp's Avatar
Anyone know a place in Northeast Jersey or NYC area?
Old 02-24-2010, 02:32 PM
Blackjack
Blackjack's Avatar
I think I paid $179.
Old 03-04-2010, 01:48 AM
w1ley
w1ley's Avatar
Hi...live in langley..
mind if i ask who lowered your ride?
and did you put in a rear camber kit with toe adjustment.
tks.
Quick Reply: Installing springs(question)
