Request: cleaning stillen gen 3 filters
Old 02-18-2010, 01:15 PM
jc562
jc562's Avatar
Can someone please post a step by step diy on cleaning the filters for stillen gen 3 intake I search but all I found was instructions for cleaning the drop in filter
Old 02-18-2010, 01:39 PM
G37Sam
G37Sam's Avatar
There's barely any room to do it through the radiator cover, I suggest going through Igor's DIY just to remove the bumper (do not remove the entire thing, just leave it hanging on the lower clips)
They should be visible from there, I can't remember which wrench I used, 10-12mm one maybe can't recall and a flathead to loosen the clips that hold the filter. Wiggle them arround to have them taken out then use an air blower from inside the filter and outside to clean that thing, you should be set. I didn't oil mine though.
Hope that helps
Old 02-18-2010, 01:40 PM
J2S2M
J2S2M's Avatar
Instructions to clean the filters would be same as doing a front grill removal. Once the grill is removed, removed the 2 cone fiters, clean them, dry them, oil them, then try again, and finally reinstall them.. VOULA!
GL!!!
Old 02-18-2010, 01:52 PM
J2S2M
J2S2M's Avatar
^ I cleaned mine off of a sedan btw. Might be a lil diff on the coupe.
Old 02-18-2010, 07:15 PM
hispeed-lowdrag
hispeed-lowdrag's Avatar
You can either remove the grille, or just take off the radiator cover then take them out from the top and wash/reoil them.
That being said, unless you live in a VERY dusty area, they only need to be cleaned every 50,000 miles (that's the minimum too...straight from Stillen)
Old 02-18-2010, 07:23 PM
G37Sam
G37Sam's Avatar
I don't think you can take them out from top
Old 02-18-2010, 07:59 PM
hispeed-lowdrag
I've done it before when I thought they needed to be cleaned waaaaay more often, before Josh@Stillen corrected me on the wash/reoil interval
Old 02-19-2010, 02:18 AM
jc562
jc562's Avatar
So I used the recharge kit is it possible to over oil them? And sorry I was asking how to clean the filter themselves the intake isn't installed I bought them used and they were pretty dirty
Btw thanks for the info for future reference
Old 02-19-2010, 10:38 AM
G37Sam
G37Sam's Avatar
Did you un-install the filters? or just cleaned them while mounted?
Old 07-26-2010, 09:43 AM
Only4theGnme
Only4theGnme's Avatar
So what is the correct cleaning interval??
Old 07-26-2010, 10:05 AM
hispeed-lowdrag
According to Stillen, it is every 50,000 miles. Since a recharge kit is <$20 and lasts at least 3 cleanings, I cleaned my Gen3 at 20,000 miles and plan to keep cleaning it every 20,000 miles.
Old 06-07-2011, 03:24 PM
ipitythefoo
ipitythefoo's Avatar
Bumping this thread. To remove the filters to I have to loosen the hose clamp thing and the nut that attaches the front of the filter to the splash guard thing?
Old 04-25-2014, 04:54 PM
kilya
kilya's Avatar
Bringing this guy from the dead!
Could use some more insight. I am installing mine this week but will be good to know if I can take out the filters without droping the bumper. Ill make sure to make the clamps reachable from the top
Old 05-22-2014, 02:16 PM
GORILLA GAINS
GORILLA GAINS's Avatar
bump for going through the top?
Old 05-22-2014, 05:06 PM
cecrops
cecrops's Avatar
Depending where you left the clamps, then yes you can reach them if you took off only the radiator cover. At least I was able to.
Quick Reply: Request: cleaning stillen gen 3 filters
