Getting ready to paint my grille
Old 12-19-2009, 05:51 PM
wakeboardr116
wakeboardr116's Avatar
I went to autozone and got some duplicolor adhesion promoter, black paint for plastic, and some high performance wheel clear coat. I have a brand new grille I picked up on ebay that i'm gonna do it on. So do I need to scuff up the chrome or anything on the grille first or can I just spray the adhesion promoter on and be fine? Here are the steps I plan to do.
-scuff the grille first (if needed)
-wipe down with alcohol and let dry
-spray 1-2 coats of adhesion promoter
-sand with 1000grit to clean up over spray
-spray 3 coats of black
-sand final coat with 2000grit to clean up overspray
-wipe with alcohol let dry
-then spray with 5 coats of clear and let dry for 24 hours
so does this sound alright? anything i missed or should change?
Old 12-19-2009, 05:57 PM
Make sure you sand the entire surface you are going to paint very well. That is the key. I don't know about the adhesion promoter, I'd personally just use primer. I didn't do any sanding after the color coat either, just let it dry and then clear coated it.
Old 12-19-2009, 06:06 PM
wakeboardr116
Ok. I talked to the guys at autozone and they said the adhesion promoter is better for plastics. Its pretty much primer for plastic. Also, I searched around and people said not to sand the plastic too much, otherwise it will look uneven. Just to scuff it up alittle to give the stuff something to bite on.
Old 12-19-2009, 06:07 PM
Kidcane
Florida G Club
Kidcane's Avatar
Uh yep use a low grit sand paper.
Old 12-19-2009, 06:11 PM
wakeboardr116
I'll see what the lowest I got is. I think its like 220. Would that be enough or should I go buy some lower?
Old 12-19-2009, 08:28 PM
wakeboardr116
K, I got the grille all scuffed up and wiped down but I have a little problem. Its only about 50 degrees in my garage with a space heater going and doesnt look like it will be much warmer tomorrow. Will it be ok to paint this cold? (im gonna turn the heater off during painting, i dont wanna explode) The can says it goes down to 50 but just am not sure.
Old 12-19-2009, 08:34 PM
JMacsG37
JMacsG37's Avatar
Check this thread out...it has alot of good info on painting your grill https://www.myg37.com/forums/body-in...ht=paint+grill
Old 12-19-2009, 08:41 PM
wakeboardr116
Thanks, but that doesn't really help with my temp problem.
Old 12-19-2009, 08:45 PM
Ivoidwarranties
Ivoidwarranties's Avatar
Too cold. Read the can.
Old 12-19-2009, 09:00 PM
speedracer g37
speedracer g37's Avatar
you should be using 600 wet/dry or even a scotch brite red scuff pad to prep the grill. there is absolutely no need to sand in between the adhesion promotor and basecoat--you will remove all the adhesion promotor by doing so. absolutely do not sand between basecoat and clearcoat. 50 degrees is not a good temp to to be painting. wait for 70 degrees and up.
Old 12-19-2009, 09:03 PM
speedracer g37
220 grit is for removing paint and knocking down body filler. painting over it will result in scratches showing in the final product.
Old 12-19-2009, 09:31 PM
wakeboardr116
I found a scotch brite pad and used that. After googling i realized 220 would be way too much.
Old 12-19-2009, 09:33 PM
wakeboardr116
I also googled around about painting in cold temps (since its only gonna get colder for the next few months.) and found some info. My garage is at a steady 50. Here's what I did for the first coats of adhesion promoter and it seems to have worked well. Warmed the paint cans in warm water then sprayed the grille and waited a min then hit it with a hair dryer on low heat. Then brought it in to a warmer area to finish drying. So far is looking pretty good.
Old 12-19-2009, 10:30 PM
wakeboardr116
Well so far so good. This process is working really well. Got my 4th coat of color on and am now waiting for it to dry to start the clear. I'm gonna have to wait to finish the emblem tomorrow. Need to go get some smaller tape to tape it up with.
Old 12-19-2009, 10:35 PM
STOOF
STOOF's Avatar
Do not sand it. Just scuff it with a scothbrite pad. Clean it and paint it.
Clear from a spray paint can NEVER comes out good. So i wouldnt recommend it.
If you can just paint it and bring it to a local body shop and ask them to clear it. Should be cheap.
Quick Reply: Getting ready to paint my grille
