DIY: How to Replace Cabin Filter and Glove Box Bulb
Old 10-13-2009 | 06:16 PM
Redline37's Avatar
Redline37
Hey guys. It just stopped raining, so I decided to do my DIY on how to replace the cabin filter and glove box bulb.
1. Open the glove box.
2. Pull glove box up.
3. Remove damper pin located on the left side of the glove box.
4. Push right side of the glove box up and left side down.
5. Next you will need to remove the bottom cover.
6. Next, you will have to remove the right side panel.
7. After the covers are off, unscrew the seven screws circled in red.
8. After taking off all the screws, pull lower assist panel off.
9. Replace glove box bulb with .5 Watt bulb or LED. Simply plug n play.
(make sure to have the LED in the correct +/- side. Before putting everything back, check if the LED turns on when the car is on. The glove box light only turns on when the car senses that it is dark [in auto], so make sure you switch the lights to all on rather than auto.)
10. Remove air filter cover and replace cabin air filter. (I decided to switch to a carbon filter)
11. Now reverse all the steps and your done!
JUST FINISHED!! Aww, it started raining again :[
The following 9 users liked this post by Redline37:
Black Betty (04-28-2014), G.AWD.zilla (04-24-2017), G37xhibeet (02-04-2015), hybridamp (09-06-2014), Infinitard (02-09-2014), Ivoidwarranties (04-23-2013), NealP (08-29-2017), Sway_NV (08-20-2014), VIVID (09-07-2015) and 4 others liked this post. (Show less...)
Old 10-13-2009 | 06:28 PM
nogoodname's Avatar
nogoodname
thanks for the awesome diy !!
Old 10-13-2009 | 06:33 PM
Mike P's Avatar
Mike P
Great DIY. Why did you change to the carbon filter?
Old 10-13-2009 | 06:41 PM
Redline37's Avatar
Redline37
The activated charcoal provides additional filtration against objectionable outside odors and pollutants such as hydrocarbons, sulfur dioxide, nitrogen dioxide, and ozone.
Old 10-13-2009 | 06:42 PM
Ivoidwarranties's Avatar
Ivoidwarranties
About time someone steps up with a quality DIY post. The tricky part for me is always putting the glovebox back in with that retraction system. I nailed in about 3 seconds one time and another time it took me about 10 minutes to get it right.
The carbon filter will filter better. Better for some people with bad allergies. Some argue it will take some smell out of the incoming air too.
Old 10-13-2009 | 06:43 PM
Redline37's Avatar
Redline37
More than happy the help out the myg37 community!
Old 10-13-2009 | 06:49 PM
G37Sam's Avatar
G37Sam
Thanks for the DIY!
Old 10-13-2009 | 07:19 PM
vukhey's Avatar
vukhey
Ahh I needed this, thanks for a great DIY.
Old 10-13-2009 | 07:58 PM
TreSe7en's Avatar
TreSe7en
Where would I find these filters? At the local autozome?
Old 10-13-2009 | 08:11 PM
Redline37's Avatar
Redline37
PM sent!
Old 10-13-2009 | 08:16 PM
amoney805's Avatar
amoney805
Great write up thanks!
Do the filters only work when the air is circulating?
Old 10-13-2009 | 08:22 PM
Redline37's Avatar
Redline37
Whenever the air is flowing through the filter, it is being used. That will include both when the vents for the ac are closed or when they are open. I personally leave my ac vents closed at all times. But that's just me.
Old 10-18-2009 | 03:40 AM
Gunit37's Avatar
Gunit37
I can save a lot of $$ by doing this myself. Thanks!
Old 10-21-2009 | 11:37 AM
hyekid10's Avatar
hyekid10
is this the filter which air passes thru wen u have the a/c on or the vent that allows the air to come in from outside? if so this is fabulous, plus id like to know where u bought that filter so i can change mine.. i got 26k miles and i only do oil change to the car but i need to step up and do a oil flush and **** to give the car a refreshing feel..
Old 10-21-2009 | 12:08 PM
Triple_X's Avatar
Triple_X
awesome writeup. Thanks. This will def save me a crazy amount of money the dealer would charge.
