I m following Igor's DYI on headlight removal and got as far as taking headlight off but I can't figure out how to take off the harness with hold all the wires going to the various bulbs. This is the last piece before I can package my light and mail them off.
Please Help!!
Thanks.
on the bottom side of the plug there should be a little tab you press in and it releases. Try using a small flathead screwdriver or needlenose pliers to press it in.
Yeah please pay close attention to putting bubble wrap on the top corner around the guide stem, that tends to break easy along with the corner of the clear lens on that corner too.
It is well worth the investment to buy a long roll of bubble wrap to make sure they are wrapped very good and then spend the dough to completely fill the boxes with Styrofoam packing peanuts so they can't move around at all and are totally cushioned. Towels may not be shock absorbent enough for transit and if they break you'll wish you'd spent the few extra bucks. Also, be sure to clearly and largely mark the box "FRAGILE" on all sides. Trust me on this.
taking my harness off as well....having issues...where the rubber grommit is that the green and black wires go through down in headlight...I got the grommit out but how do you get the green and black wires out from inside?
