DIY: Key Hole Delete
#36
I don't think it's wise to replace the whole thing. In case your key battery is ever dead you can still get the cover off to access the original key slot. I know you get a low battery warning or you can go buy a new battery, but it just seems smarter to leave it there and cover it up. Looks the same from the outside and is less work.
#39
Got mine from Riverside Infiniti, they have an eBay store with tons of parts, it's like $30 shipped.
I'd say be sure to wrap the screwdriver in a towel or something as my stock piece was a PITA to remove and I ended up scratching my door above the handle because I didn't wrap it up.
#43
I think i have the worst luck with any mods no matter how simple. I ordered the key hole delete cover. I received one...although it is for the G35. Ours our flat on the end, this one is concave. Back to the dealership i go.
#44
Just did this mod on the coupe ('11). Was worried that the paint would get scratch so went about it the traditional way, by pulling out the plastic hole cap on the side of the door and using the 5/32 hex key to have a little more leeway. Would have been a 5 minute deal but the hex key fell into the door. Had to take the door panel off. Took about a half hour to fetch the key but I was actually quite surprised at how easy it was to remove/replace the door panel. My Volvo C30 was a nightmare to remove. For some reason, Infiniti seems to be quite mod friendly as opposed to other brands.
Anyway, the key delete looks great and no scratches!
philttz
02-17-2016 11:26 AM
FlyIce
09-29-2015 04:07 AM
AMai1215
09-13-2015 12:59 PM
