DIY: Changing rear differential gear oil
#62
I guess I should have been more specific, like what is the specification of the factory fill. I am really trying to find the actual viscosity ratings and VI, but if someone knew the name I could track down the specs. TVPostSound understood the gist of the question.
#63
Oh,I thought you actually meant what brand is it. For the '08 I posted the viscosity in the first post. I haven't checked to see if it's changed in subsequent years but I doubt it. I don't know all the egghead technical specs of the fluid, only the viscosity.
#64
Did this yesterday. I was going to jack up all 4 corners at first but decided I'd try and get under the car without putting it on stands. Was able to squeeze my way under the rear of the car (and I'm not a small dude at 6' 220 lbs) and get the fill plug out first, then drained the fluid into my catch pan. Let it drain for a good 20 minutes while I changed the cabin air filter... easy peasy. Made me miss wrenching on my Jeep and my truck that I had before this car, but it was nice not having to remove the diff cover and deal with the RTV and all that.
The fluid that came out was the factory fluid - had 33.5K miles on it and looked/smelled normal. Pic of the drain plug below. Filled it with Mobil1 75W-90.
Spyders (01-08-2022)
#65
LOL
Pull the cover,,,,,,,,,geesh! Nice way to be diplomatic Double B.
Bandit..................
The thread's intent was simply a how to on how to perform the PM of changing the differential fluid, not anything detailed or with any expanded application other than basic maintenance. However, feel free to add to this write up with photos and the steps for pulling the differential cover and what to inspect for inside. You can expand it's scope since this a field of expertise for you.
It seemed to be wearing fine from what I can tell by looking at the fluid. But I'll know much more when it's time for the gear swap and a professional with a lot more expertise than me tears it open.
#66
Question regarding friction modifier-
To my limited knowledge.. TV was suggesting adding a friction modifier because you have the S with limited slip diff.
I have the journey, no lsd, so I don't have to add a friction modifier?
I'm planning on using Mobil 1 75W-90.
#67
Bringing this back since im looking at doing my diff fluids. I have an LSD, so if i get the this Motul Performance Oil Store - MOTUL Authorized Dealer , I do not need to add the modifier as well? Or do i still need to add the modifier?
#69
I did a little more research and the Motul 300LS is all i need. Its made for Nissan LSD's so i should be fine. A local guy is running in it his 575 whp TT 370 and has never had a problem.
#72
Just say no!!!!!
Chatter sounds/feels like the rear end is binding up. Easiest way to test for this is to to turn the steering wheel hard lock to one direction, then start moving at slow speed. If there's no binding/chattering (keep windows down), then you're fine.
I'd get this occasionally in my old taxi cab (posi rear end) when I didn't use the additive.
#73
I'm going to use the Amsoil synthetic gear lube. The product description says it's compatible with most LSD's but if chatter occurs to use their additive. I'd really rather not have to jack the car up and get under it again to add the additive after the fact if I need it. Is there any harm in just including it in the first place? Or does the Amsoil lube alone reliably provide everything our cars need?
handleandrew (09-28-2013)
#74
I'd hold off on the additive, but to answer your question....I don't think it would harm anything to just include it anyway.
