DIY: Changing manual transmission oil
Does anyone know if Infiniti/Nissan recommends doing a machine flush (so much force that it shreds a bit of wall on the interior of the transmission)? As apposed to a 3x3 drain and fill?
Redline MT90 in G37 6MT
FWIW, Red Line recommends a 50-50 mix of their MTL (70W-80 GL4, part number 50204) and MT-90 (75W-90, part number 50304) manual trans oils for the Nissan/Infiniti manual transmissions and their 75W-90 GL5 gear oil (part number 57904) for the G37S rear end with viscous lsd.
Thanks for all the great advice here. I just did a search on "manual transmission oil" and got to the right place quick!!
-James
Important update: A representative from Redline Oils just wrote back to me that their new version of MTL is in fact a 75/85 weight manual trans oil. So no blending is needed if you get their new MTL for any of the G/Z cars! I will try it out shortly and report back to you all.
Disclaimer: I am a complete novice and am not a marketing person or oil viscosity expert for that matter. I'm just a Nissan fan and also a fan of Redline per my experience through past use in my old Nissans.
Check it out.
Redline makes the correct blend for us now.
Red Line Synthetic Oil - New From Red Line: MT-85
Check it out.
-James
Check it out.
I see that press release even says, "we think this fluid will be a hit with Nissan Z-car fans." Close enough!
The only procedure listed in the service manual is for a drain & refill. That's all I know.
I know you're suppose to have 3qts for the transmission but I accidentally spilled half of a bottle because of my clumsy self. So I ended up only putting 2 1/2qts. Will that suffice for normal daily operating? Also, as I was pumping it the 2 1/2qts, nothing spilled out.
#29
Hi everyone, long time no posts!! I finally got some MT85 from my local NAPA store, it took a while for them to be able to order it. Anyway I went to my favorite quick change place, they raised the price to 30 bucks since last year to do a manual trans change, still pretty cheap. Anyway with the MT85 in the gearbox the trans is shifting very smoothly and I can even engage 1st gear while creeping along. Also when the car's cold I can shift from 1st to 2nd, couldn't do that with MT90 without some gear crunching. Anyway, I highly recommend the new Redline MT85 for our cars!!
The following 2 users liked this post by jabrother:
handleandrew (09-12-2013),
jason56765 (12-25-2019)
#30
I'll get another bottle and pump some more in today. I just didn't have the time for it yesterday. But thank you so much for the reply.
