DIY: Changing manual transmission oil
Old 07-09-2018 | 12:00 PM
  #151
JSolo's Avatar
JSolo
Just say no!!!!!
^^You're in the wrong thread - review this https://www.myg37.com/forums/d-i-y-i...-gear-oil.html
And yes, for your region (pacific NW) 75w140 would be too thick IMO.
Old 03-12-2019 | 09:25 PM
  #152
steakpowered's Avatar
steakpowered
Read the entire thread and looks like MT85 is the way to go? I live in San Diego and don't see a lot of cold here. I have an amsoil membership that is expiring soon and would like to use it if possible for the MT fluid. Also, the 09 vert FSM calls out for 3 quarts. What's the extra 4 oz for?
Old 03-12-2019 | 09:46 PM
  #153
JSolo's Avatar
JSolo
Just say no!!!!!
On a level surface I've always filled it til it starts over flowing... Wait until stops, then reinstall the plug. It did take a bit more than 3 iirc.
Old 03-13-2019 | 01:52 PM
  #154
steakpowered
You guys think Amsoil would be fine if the coldest it gets is mid 40s?
Old 06-19-2019 | 05:31 PM
  #155
Glenn2008's Avatar
Glenn2008
Just changed my MT oil. I used Redline MTF and IMO the car seems to shift smoother. I used the Harbor Freight syphone pump. Worked great, no runs, drips or errors. I had 32K on the Nissan MTF oil. Definitely needed changing..
Old 06-19-2019 | 11:37 PM
  #156
JSolo's Avatar
JSolo
Just say no!!!!!
^^Funnel and hose works just as well with less effort. Used this both for the diff and trans last time. Best to do both on a hot day (fluid flows more easily).
Old 06-20-2019 | 05:40 AM
  #157
Glenn2008's Avatar
Glenn2008
Thanks, I'll have to remember that. Didn't consider gravity filling it from the top.
sharmelan
17
09-14-2015 03:18 PM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: DIY: Changing manual transmission oil
