Samco Install DIY?
Samco Install DIY?
Any DIY (preferably with pics) on replacing the radiator hoses with Samcos?
Guess I'm confused on how changing hoses out is a 2 hour job.
Edit: Would you mind taking pictures when you do the install? (also how long it took you)
After reading the FSM, I opted for Function: TUNED to do it. It is a messy job and when I had it done it was too cold in the garage. After watching him do it (took about an hour start to finish), I was glad I did not attempt it. A lift was a big advantage. Worth every penny for an hour of labor.
Correct me if i am wrong...i do not think you need to purge it unless you have high mileage on the vehicle or the vehicle's thrempstat is jumping around. I did for the g35 and it has over 60,000 and did not need to purge it. The way i purge it was having a medium funnel with the coolant on there and having the engine run so it elimates the air bubbles in the coolant.<--that was for the impala i had so...take it for what it is worth
