DIY Scratch Removal on Polished Intakes
So I scratched my Stillen Gen3 tubes during the install becasue I did not want to remove the bumper.
Not wanting to have my new intakes look like crap, I decided to fix them myself.
Materials:
220 grit wet/dry sand paper
400 grit wet/dry sand paper
800 grit wet/dry sand paper
1000 grit wet/dry sand paper
Fine steel wool
Metal polish
Rags
Some free time
I started by using 220 grit paper, DRY, to remove the scratches as shown.
I then moved to 400 grit WET to remove the marks from the 220 grit
Next step was 800 grit WET to remove the marks from the 400 grit
After the 800 grit it was time to move to 1000 grit WET to remove the marks from the 800 grit
After all the sanding was done, I went over the whole area with fine steel wool
Finally I used a good metal polish and made it all pretty
That was all it took to make it look better than it was out of the box. I had to do the same thing for both sides but as you can see, the scratches can be fixed with a little work.
Materials:
Fine steel wool
Metal polish
Rags
Some free time
Awesome write up. Me and my brother had installed my Gen 3 and we didn't take off my bumper and he scratched the crap out of one of my tubes. I'm gonna make him fix it now.
I just did this the other day. The result was a lot better than if I had left the intakes scratched, but I had one very minor problem. I couldn't seem to get the mirror polish look that the intakes came in. Where I did the sanding isn't really noticeable unless you're staring, but of course I always know it's there. LOL. Overall, would I recommend doing this...absolutely.
Edit: Originally I hadn't used any grit higher than 400, but I went over the area again with 1000 grit and again steel wool. I have to say that I got a pretty nice finish, better than before. I'd give my results an 8/10
SchoonerVanHlmt
Intake and Exhaust
09-20-2015 01:03 PM
