drilling and cutting holes into the cap wont create humidity in your headlight right .. cuz here in miami it rains A LOT ! lol .. and like im scared that it will cause a problem
I'd like to replace the yellow fogs with something bright white/blue, but these DIYs are much more involved than I want to get into for this project. Is all this necessary just to change bulbs?
it sounds a lot more involved than it actually is. once you get the tire off, it takes MAYBE 10 minutes. easiest and fastest mod yet besides LED's
EDIT: and just an FYI for the OP and everyone else...HPA is using a newer, easier fog HID ballast that is a lot simpler. No cutting, drilling, simply mount the ballast and then plug/play
