Cheap $3 & 3 minute headlight restoration
Old 03-12-2021 | 02:25 AM
BrixRide's Avatar
BrixRide
Smile Cheap $3 & 3 minute headlight restoration
This has probably been mentioned before over the years, but... I just wanted to share a moderately effective way to take the fog out of older headlights. For $3-$4 you can achieve nearly the same clarity as headlight restoration kits that cost 5-10 times as much, or more. This works better than the toothpaste approach, because it's not nearly as messy, and only takes a fraction of the time. Please note, this is just a temporary solution and only lasts anywhere from a few weeks to a few months depending on your local conditions, and if your car is garaged or not. If you really want to achieve a more permanent solution, then you should go the sanding/clearcoat route.
Tyrell0837
02-13-2017 07:42 PM
rolltidealumni
06-04-2016 10:37 AM
vxo5028
11-20-2011 03:02 PM
like_a_g37
45
04-15-2011 01:26 PM
dahamsta7
16
03-25-2009 06:07 PM
Quick Reply: Cheap $3 & 3 minute headlight restoration
