Opti-Coat 2.0?
Opti-Coat 2.0?
Anyone on here put Opti-Coat 2.0 on their car?
Optimum Opti-Coat 2.0 Permanent Paint Coating | Free Shipping Available - Detailed Image
I like my car looking good, but my time is valuable to me. Therefore, I try to use products which are easy to apply and have good longevity.
I'm currently using Blackfire Sealant as i've found it lasted a little longer than the Menzerna FMJ that I used to use. And I use Optimum Opti-Seal spray on sealant for my rims as its much easier and quicker to apply vs. the PoorBoys wheel sealant.
I put the Blackfire on once every 4-6 months, and then after washing the car, I use the Blackfire spray on sealant as a "booster" in between full sealant applications.
The DI professional review stated that Opti-Coat 2.0 can last significantly longer than Blackfire, so I'm wondering if anyone has used it on their G and what their thoughts were?
Opti-Coat has better resistance to chemicals (acid), scratches and release properties than other automotive coating currently in use. This coating has a 2-4 µ (microns) applied thickness and a hardness of 9H (Pencil Hardness) when fully cross-linked (90 days) and provides a semi-permanent coating. Its application is similar to that of a single component Isocyanate that forms a semi-permanent clear coat finish and lasts almost indefinitely. Unlike waxes and paint sealants that require frequent reapplication.
When applied by OPT approved profesional detailers, the Opti-Coat finish is guaranteed for five (5) years
TOGWT® Autopia Detailing Wiki Article - “Nanotechnology coatings “- http://www.autopia.org/forum/autopia...-products.html
These Detailing Wiki informational resources contain everything you’ll ever want to know about automotive detailing and are an invaluable addition to your detailing knowledge base -. http://www.autopia.org/forum/autopia...yperlinks.html
![Frown](https://www.myg37.com/forums/images/smilies/frown.gif)
NACZ3
B4 'n Afta
11-08-2010 12:37 AM
