Using an Orbital Buffer
I'm new to car detailing, and I just recently purchased an orbital buffer from autozone for $25. I'd like to know when in the detailing process should I be using the buffer. Should I use the buffer to apply the polish after wash/dry? Should I also use it to apply sealant? How often should I use it?
Thank you for your help!
Check this website out: everything you need to know about detailing.
We Are Car Care -- Car Wax, Car Polish, Auto Detailing Supplies, Car Buffers & Car Accessories Store
What I consider to be the best PC How-To available -Machine Polishing By Dual Action Polisher, Dave KG – Machine Polishing by Dual Action Polisher - Full Guide - Detailing World
I have also never used a polishing tool, but I plan on getting a dual-action polisher to remove the swirls on my 2009 G37. I don't have large enough scratches to warrant me buying a circular tool and running the risk of burning the paint, but I do have a question about dual-action; is there a limit to how much you can use the tool? For instance, if I polish now, and then notice swirling in a year or so, do I run any risk polishing the same area multiple times?
Auto Detailing Expert
Unfortunately many of those less expensive units don't have the necessary power to work in a polish properly and some of those bonnets may not be ideal for the paint. I'd highly recommend considering a Porter Cable 7424 XP if you want to be sure you'll get great results. Either way I'd suggest our detailing guide should have a lot of good information for you, especially the Polishing section. I'd also highly recommend checking out our Ask a Pro Blog, which has tons of good articles about maximizing a buffer direct from elite professional detailers. Good luck!
Greg @ DI
Greg @ DI
first step would be returning that $25 buffer.
Give this Porter Cable 7424XP a try.
You will want to use it to apply polishes for correcting paint imperfections. You can use is to apply glazes and sealants for ease of application using a softer pad and lower speed setting.
Meguiars M105 is my favorite cut compound for correcting swirl marks and moderate imperfections with a orange buffer pad. Then use Meguiars M205 to clear out any hazing and bring out a brilliant shine with a white buffer pad.
Greg @ DI
Greg @ DI
Detailed Image
Car Care & Detailing
08-12-2009 02:26 PM
Detailed Image
08-11-2008 12:52 PM
