Zaino Z5 Pro and BlkFire Wet Diamond Sealant...
Ok I've done some research and can't find the answer to my question so I'm hoping someone can help. I will be detailing my car next week, I already have Blackfire Wet Diamond Sealant and was looking for a polish. Zaino Z5 is listed as a polish on many websites and on others it's said to to the same job as the BF sealant.
My question is can I use Z5 as a polish (after I clay my car)? Also, can it be followed up with BF sealant? If not what's a good polish to use with the BF sealant?
Thanks!
Thanks!
Not sure if this will help but here:
http://www.clublexus.com/forums/auto...l-himself.html
Thanks!
Thanks!
If you are looking to maximize your time I would suggest picking up a different kind of product. I would suggest a quality polish like the Meguiar's M205 which will help remove oxidation, light swirls, etc. restoring a deep shine to the surface. Polishing is the most important step in creating a shine so I highly recommend adding a polish to your routine. Afterward apply the BFWD and it should really enhance the shine you just created! Hope this helps!
Greg @ DI
