Help Pressure Washer + Buffer!
I have the PC and the Flex. If I'd bought the Flex first, I'd never have considered the PC. IMO It's much better. And much more expensive.
Flex XC 3401 VRG | Detailed Image
I'm still undecided on a new pressure washer. I'm considering this one:
Shop Worldwide Lighting Antique Bronze Flush Mount at Lowes.com
Lol. Hardly. The Flex is a lot more than the PC. But in fairness, it's a lot more tool than the PC as well IMO. It's an investment. It a good value for me because I detail my own car as well as getting paid to detail other peoples' cars. The amount of time it has saved me over using the PC has more than made up for the difference in price.
if you are new to buffers, get the porter cable as it is a bit more for beginners..the flex is the best but that's only if you know what you're doing..Porter Cable tends to be a bit more forgiving so I have been told and read..read this, it some awesome awesome info
Polishing Auto Detailing Guide - Detailed Image
I'm looking at the same stuff as the OP. Why do you feel the PC is better for beginners Goonz?
Having used both, I can say that the Flex requires just a little bit more skill. Not a ton. However it's kind of like first learning to drive a manual transmission on a car with an unforgiving stiff clutch. If that's what you learn on, it's not so hard to you because you have nothing to compare it to. And once you have it, everything else will be easy.
Having used both, I'd always recommend the Flex over the PC. It's not hard to learn at all. Just a little more advanced to control it well thatn the PC. Have patience and practice first on an older finish that's not your pride and joy and you'll be fine.
If it's a budgetary issue, go for the PC. Then as you get better and want to advance you'll find yourself springing for the Flex later anyway. I know this form experience.
