Washing YOUR CAR?!
Washing YOUR CAR?!
Objective: Get your car as clean as possible with as little to no scratching at all to your clear coat during the process.
Options: Optimum No Rinse. Snow foam w/ pressure rinse. ETC...
I want to know what method you use !!!
Washing:
Gilmour Foamster II foam gun
Various CG shampoos (CG HoneyDew Snow, Maxi Suds II, Citrus Wash and Clear, GlossWorkz)
Chenille MF mitt
Drying:
Weed Eater electric leaf blower
Waffle weave MF drying towel
Chenille MF mitt
Drying:
Heading to Home Depot now!
I thought everyone knew about blow drying the car. Guess not. The one I got was about $30 or so on Amazon.com. Especially if your car has wax or sealant, the water just flies off with a leaf blower. You can also completely dry areas that are impossible to get to with a towel, your engine bay after you wash it down, the crevices of your door handles, rain channels around the trunk and tail lights, the hood cowl, and especially the side mirror housings that always hold water long after you are finished drying with a towel to drip on your door as soon as you start to drive. It is the best $30 you'll spend for washing your car. It helps me to get the majority of the water off of the surface very quickly so that if I have to work when it's somewhat sunny it doesn't leave water spots. After blowing it down, I use the towel just a little bit. Hardly at all.
so back to the point.
Alan318, when you say method are you speaking specifically about the steps of how we physically go about washing the car?
Wet it with a hose. Foam it with the gun. Wet the mitt and wash it a panel at a time starting form the top down. Rinse the mitt out with the hose between panes or anytime it looks visibly dirty. Rinse the car off with the hose. Dry with the leaf blower then the towels.
I don't use 2 buckets because I use the foam gun so I don't need a soap bucket. I do have a rinse bucket for my wash mitt but I use the hose to wash the mitt out well. Light strokes with only enough pressure to wipe the dirt away, not grind it into the paint. Remove the nozzle for your final rinse and sheet the water over the car, it will pull more water off then spraying a stream.
