Newbie first time using clay bar what polish and or wax to apply??
Hi guys
I am newbie and first time using clay bar, I have seen couple of videos on you tube which shows how to apply clay bar.
I picked up mothers clay bar kit from walmart the other day.
Once I apply the clay bar what polish and wax should I use that can be found in my local walmart?
What type of buffer or applicator should I use??
I don't want to spend hours doing this so a laundry list is not going to work. I want the basic stuff to try out first and see if I have the patience to do this
Thx in advance
Thx in advance
If you're going to stick to applying local polish from walmart I'd say go with Meguiars ultimate polish followed by NXT 2.0 wax. you should look into getting a porter cable 7424xp or a flex, and then there's a buncha pads by lake country. Check with Detailed image, they have a lot of great kits and packages. I just finished claying my car today, going to polish tomorrow with Manzerna super intensive polish followed by a finer menzerna polish, sealant...maybe glaze if im still up for it, and some dodo juice wax. Good luck
(btw with your clay bar, break it in half, use one half for the upper part of the car, and the other half for the lower half of the car)
Claybarring a car removes the dirt and grime that is on the car after you wash it. If you take a plastic zip lock back and put your Hand in it and rub across the car you'll feel all that dirt. Clay bar removes all of that to give your car a nice smooth feel.
If you're a beginner a great Buffer is a random orbital like griots. I love it and it will not burn through your paint.
is that something that should be done? or us the quick detailer which comes with the kit?
Also i cannot find NXT 2.0 wax in my local walmart, any other wax do you recommend that is easily available locally?
When i polish do i have to wait to put the wax or i can put it immediately?
thx
Just use the quick detailer, it should be enough.
Try Meguiars gold class carnuba or meguiars ultimate liquid wax...you should be able to find that at walmart.
you can put the wax on after u polish, there's no wait time. You usually have to wait only if you use sealant, which in your case you're not using.
1. Wash your Car
2. Clay your car (use a generous amount of quick detail so the clay easily slided over the car. At first it will feel as if you are rubbing it over bits of sand/dirt. This is normal, keep working that area until it is smooth and does not feel gritty anymore.
3. Wipe the whole car dry
4. Polish the car (Although not as effective as using a machine polisher, such as the porter cable, you can use foam applicator pads which can be purchased at walmart and other local auto stores) A good polish from walmart is Meguiars Ultimate Polish.
5. After polishing it is best to rinse off your car again to remove any residue left behind.
6. Wax the car (you can use the same foam applicator to apply the wax. A good choice of wax from walmart is Meguiars Ultimate wax.
That is a basic little run through of the process you can use to get good results, given the circumstances. (No machine, and store bought products) Depending on your goals, i would suggest picking up a machine polisher(porter cable), and some products from sites such as detailedimage.com if you are looking for results. I have tried almost all store bought products and none can really compare to some products you can find online and for around the same prices.
If you decide to buy a few products online, i would suggest Meguiars M105, Meguiars M205, and a wax such as P21s concours Carnauba wax.
1. Wash your Car
couple of follow up questions, can the polish and wax be done outdoors in the sun? or has to be in indoors? I can use machine polisher when waxing as well?
I plan on doing this in a week or so, can you please provide me some links to the detailed image side of basic things i would need for a newbie like myself including a machine polisher, if it will cost the same might as well get it online.
thx
Has to be 100% indoors and on a cool surface. The reason you get swirls in your paint is majority from car washes in the sun.... The paint is super hot and on top of that circular motion with towels, microfiber towels, whatever you use, causes more heat and more swirls. So only inside...or outside but when there is no sun and the car is cool to the touch
