Summer Detailing
Summer Detailing
alright guys im planning a full detail of my car later in July. I used the 20% off coupon from DI and purchased the following after much research.
Blackfire Gloss Enhancing Polish (with Glaze fillers)
Chemical Guys Jetseal 109
P21S 100% Carnauba Wax
Dodo Juice Red Mist Tropical Protection Detailer
Obviously I will clay bar the car prior to starting however I just wanted to know what I should use FIRST on the car and then so on. The car is is great condition, it was last detailed in April. Also a few words of advice would greatly be appreciated.
Wash, dry with electric (not gas) leaf blower, polish with Zaino, wash, dry with electric blower, Zaino detailing spray. Zaino leather cleaner and then preserver on leather surfaces.
A final wash after using an abrasive polish is to make sure that all oils and polishing residue has been removed and you have a pristine surface for the glaze or sealant or wax to bond to. Some wipe very well with a soft MF towel and simply use a good detail spray or surface prep solution like Menzerna Top Inspection or Meguiar's Final Inspection to make sure the surface is prepped.
i dont wash after polishing either. if yours hardcore you can use a diluted alcohol soultion solution to remove the oils (cant remember the mix). Lots of polishes have fillers to fill imperfections, but thats essentially what a glaze does as well, so if your using a glaze theres no need to clean the paint because your adding similar oils again. But if your going straight to a wax it wouldnt hurt
