Help Is it safe to polish scratch shield paint?
Old 05-11-2011 | 08:53 PM
Fire0nIc3's Avatar
Fire0nIc3
I was wondering if it's safe to polish my car with scratch shield paint? Paint color is black obsidian. I'm going to be using my portercable and a finishing polish to remove light swirls.
I'm wondering if there is any risks of ruining the clear?
Old 05-12-2011 | 12:39 AM
123u's Avatar
123u
If you use the right polish then you should be fine. Menzerna Super Intensive Polish (PO83) is designed for the removal of scratches, swirls, and oxidation on the scratch-resistant clear coats used by Mercedes Benz. so u know is good!
Old 05-12-2011 | 12:03 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Yes you're fine. I use blackfire polish but as long as it's high quality polish (Aka not from autozone) you'll be fine
Old 05-12-2011 | 12:50 PM
Fire0nIc3's Avatar
Fire0nIc3
Thanks for the replies. The reason I ask is because I heard stories of the clear acting weird because of the heat generated by the buffer. As I recall scratch shield clear reacts to heat.
Old 05-13-2011 | 02:14 PM
TOGWT's Avatar
TOGWT
Scratch Shield Clear Coat
Some paints (isocyanate free paint formula, a clear coat with low heat and abrasion resistance; this type of paint heats up very quickly causing the polish surface lubrication to dry out, which causes an increase in surface resistance, the pad feels like its dragging and can skip, as the polish abrasives stick to the paint
Correction - use a firmer pad that has lees surface resistance or an LC Purple Foamed Wool. Or try to add surface lubrication (Gloss- it Pad Prime) alternatively apply polish with an orbital polisher.
Chris_M
09-25-2015 09:38 PM
Cmedlin96
09-21-2015 12:09 AM
pal51961
09-19-2015 04:30 PM
Quick Reply: Help Is it safe to polish scratch shield paint?
