Looks like I messed up my paint with my PC
Old 01-05-2011 | 04:47 PM
  #31
PascalT's Avatar
PascalT
no door open but i probably pressed too hard without noticing it.. I admit the angle kinda makes it easy to push too hard since it's a narrow area to focus on.
The weird thing though is that the burn also happened on the rear door as well. Is it possible the cold outside makes it more likely to burn?
Old 01-05-2011 | 11:27 PM
  #32
Obvis07's Avatar
Obvis07
dang that sucks. well at least you know now where you should stop
Old 01-05-2011 | 11:29 PM
  #33
PascalT's Avatar
PascalT
yup.. lesson learned. there's always something positive to take out of things. Though I do get obsessive about my car... I guess it's a guy thing.
Old 01-05-2011 | 11:43 PM
  #34
1cleanG's Avatar
1cleanG
NextLevel Performance
ahhhhhh, that's like the sound of nails on a chalk board
Old 01-06-2011 | 10:01 AM
  #35
PascalT's Avatar
PascalT
I called Infiniti about touch up paint since I figured i might as well try it before spending money on a shop. The paint they sell does indeed come with clearcoat. He said something about it being 2-in-1, one side paint and one side clear.
Old 01-06-2011 | 03:44 PM
  #36
PascalT's Avatar
PascalT
update: I applied the first paint touch and the damage is not even visible anymore unless you look closely. I just need to apply another coat then sand it off and apply the clear. I'll wait a couple of days before I do this.
For $13.75, well worth it.
Old 01-06-2011 | 04:04 PM
  #37
Neal376's Avatar
Neal376
dont be too hard on yourself. whatever your car rubbed up againts took 90% of the paint away, and then the pc took another 10% down to the primer. same thing would have happened if you went to a body shop. unavoidable.
Old 01-06-2011 | 04:06 PM
  #38
Neal376's Avatar
Neal376
Originally Posted by Wezbian
I went to a body shop, the guy looked closer and then took some diluted rubbing alcohol and wiped it off. I'd give that a shot before painting. What happened with mine is the polish got hot and just stuck to the paint. Try it out!
who ever bumped into you rubbed their paint off onto your car. i guess their car/wall was white
Old 01-07-2011 | 01:09 PM
  #39
PascalT's Avatar
PascalT
no, I actually hit their bumper. The car was blue/dark. Trying to fit into a tight parking spot and then trying to get out and failing = scratches
I'm surprised so many people suggest a full body shop repaint... the touch up paint worked just fine and saved me a lot of money.
Old 01-07-2011 | 01:39 PM
  #40
cruzmisl's Avatar
cruzmisl
You have any pics of the results?
Old 01-07-2011 | 01:41 PM
  #41
philter25's Avatar
philter25
^ glad it worked out with you. Ive had very good results doing exactly what I typed up on the first page. If you take your time, for solid colors, you can get a very good match with touch up paint.
Old 01-07-2011 | 03:47 PM
  #42
PascalT's Avatar
PascalT
I'll post pictures once I am done. I still need to apply another coat, then sand it down and apply clear. Even right now you need to be pretty close to even see it, and know it's there. The color isn't a 100% match yet because it's not shiny without clear.
Old 01-25-2011 | 11:37 PM
  #43
ozzypriest's Avatar
ozzypriest
You can mix clear coat and paint together to fix scratches and dings - works pretty well, and you avoid that whole paint, et sand, clear coat, wet sand, polish ordeal. If you do it tiny bit by tiny bit and avoid getting extra paint on the surrounding areas, you can just use m205 or even scratchX to 'sand' the excess down and make it shiny.
GeezerB
Car Care & Detailing
12
01-23-2017 08:00 AM
ck1109
10-16-2015 12:06 AM
G37sPhoton
10-05-2015 12:08 AM
stm37s
The M - Spot
10-01-2015 07:53 AM
Chris_M
09-25-2015 09:38 PM
Quick Reply: Looks like I messed up my paint with my PC
