Detailing with a Clear Bra
I live in Canada, and im sure all of you know that the crap they put on the road in winter makes it a "no question" situation when it comes to getting a clear bra (specifically 3M for me). Anyways if im detailing, for example my hood (which is oviously going to have some clear bra on it) how do i go about doing it? Do i just ignore that the clear bra and detail as i would without one, or is there a special procedure i need to follow? Thanks for any input.
Traveling Administrator
Great info from TOGWT.
To remove minor scratches in the film (tape the edges of the auto mask when polishing the vehicles paint, use a high speed buffer (white foam pad only) and lightly glaze over the material. It is important not to apply a lot of pressure to the film as this may lead to burning of the surface. Use a Q-tip and some isopropyl alcohol to clean out the edge (See also 3M website- 3M Global Gateway Page)
Maintenance and Care-
1. To clean stains - use a d-limonene based (citrus) cleaner (P12S Total Auto Wash) polish the paint and the clear plastics separately, tape the edges with masking tape. It has a clear coat so it can be cared for like a clear coated paint; use Zaino or Klasse as they will dry ‘clear’. Use Z-14 Plastic Magic Cleaner & Polish™ orPlexus® Plastic Cleaner, Protectant and Polish for maintenance and to remove any finger marks / smudges (avoid the use of abrasives)
2. What can be done about wax build up along the seams and how can I avoid it?
Wax will leave a white line on the seam, it is recommended not to wax over the seams and wax the film and uncovered portions separately to keep from wax build-up. If you accidentally wax over the seam, just use a wet towel and rub it off. Another caution is to avoid buffing over the seams, which creates a noticeable wax line as well.
3. To polish-out scratches- Menzerna Final Polish II, LC White foam pad.
4. To remove ‘clouding’ from the paint under the clear bra; the suns heat, a heat gun or a hairdryer will remove it.
5.Removal -it is not difficult to remove, apply heat to a corner with a hair dryer (not a heat gun) and work slowly to avoid breaking / tearing the vinyl (like any applied vinyl, the longer it’s been applied the more difficult it will be to remove) work slowly and be patient. Detailer’s clay and /or 1:1 Isopropyl Alcohol / distilled water to clean any adhesive residue.
Note:
a) If the film is properly applied to a fully cured painted vehicle, it can be removed, usually in one piece, without damaging the paint surfaces beneath the film by pulling the film at an angle not straight up.
b) Repainted vehicles, paint must be thoroughly dry and completely cured before any attempt to apply film to the vehicle is made, in order to avoid film bubbling (solvent pop) due to paint out-gassing. Check paint body shop and / or paint manufacturer's instructions for recommended cure time and method.
Note:
Note:
Note:
Thanks for the info. I didn't clear bra my '04 G35x and regretted it. My installer for my G37XS recommended 3M cleaner for removing swirls. I use Zaino on my cars and I was definitely told to avoid the edges unless I wanted to brush the dust off. He also recommended just quick detailing the clear bra with Z-6 after a wash. Weather sucks in NJ right now. Probably won't be able to Zaino the new G for a while.
Excellent post Garnet Canuck.
I usually don't like the look of clearbras (especially if they turn yellow) but my car already came with it so I guess I'll make do with cleaning it.
Mattimus
10-04-2015 01:33 PM
