Mineralized water spots on windshield
All in one products, such as Dodo Juice Need For Speed or Klasse All In One usually work as the chemical polish does a good job removing mineral deposits. Best of all, it leaves behind some protection to help prevent this from happening again.
Glass Scrub does work pretty well if you put the effort into using it properly. You do need some elbow grease and you have to apply it on a wet surface. Only a little is needed, but it does a good job stripping glass down of any contamination.
Vinegar can do the trick as well...
Good luck.
Good luck.
Prometheus
General Tech Questions
11-09-2015 01:23 PM
Kojack
10-09-2015 05:53 PM
