what steps do i take when storing my g37 for winter?
do i need to put it on jack stands?
do i need to put anything in the gas tank?
do i need to do anything special at all to store the car, or does anyone have a list of steps and precautions to store the car for winter? thank you!!
change the oil. put on jack stands. run some fule stabelizer. and you should be good. been doing this for years for my 67 comet cyclone and no issues. make sure you ahve a full tank of gas. Will it be stored in a heated or unheated garage?. Car cover is a must IMHO too.
unheadted garage
garage is unheated, should i take the wheels off and put it on jack stands? and if i changed the oil 1k miles ago do i need to change it again? also should i disconnect the battery?
EmpireCovers-Review
Not sure if you want to go to the trouble of covering the whole car every time you park though. I think the sunshade would be a lot easier.
i understand storing a motorcycle, boat, rv, classic car, lambo... but a g37?? whatever floats you boat.. but all i would add to shumby's response is a battery tender. you can leave the battery hooked up but you should def also hook it up to a tender. otherwise you might be replacing the battery next season.
superjoey
31
03-22-2023 11:56 PM
