I am about to Give up!! "RIDS"/Swirls
Wow,
I currently own a 08 OB G37 Coupe.. For the past 6 - 8 months I have attempted to get the finish/Clear Coat of this car to look as close to flawless as possible. Being that it is a Dark colored car and a daily driver I realize that this may not be entirely feasible however I still want to remove some of the deep scratches and swirls on my finish.
I have 7424 Porter cable, white polishing pads, Orange pads, and yellow cutting pads.
For the most part I have used the White Polishing pads in combination with Poorboys SSR Pro Polish and Poorboys SSR 2.5, and recently Meguiars Ultimate Compound at speeds no higher then 5 on PC. When I am finish up the paint looks wet and has a nice depth to it... Here is the problem... Under direct Sunlight these Deep Scratches and swirls are still visible! I am scared at this point that I have polished the car so many times I am removing too much clearcoat and I am going to find myself in a Jam. I did borrow a paint meter from a friend and my car measures consistently from one side to next anywhere from as high as 4.5 to as low as 2.5(front hood).. Most readings come in at 3.5 Microns...
Is my pad/polish combo not aggressive enough? I am thinking of doing PoorBoys SSR 2.5 and Orange or yellow cutting pad, followed by Poorboys Pro Polish and a white polishing pad.. Any help or input is appreciated..
Sam Rothstein
Pairing the SSR2.5 with an orange pad should get rid of the deeper scratches. If the orange isn't enough, then move onto the yellow. Marring will most likely occur afterwards, so the Pro Polish will need to be paired with a white pad to get rid of them.
Your thread title says RIDS/swirls, but your post says you have deep scratches. If its just swirls, you should be able to get these out by using a stronger polish and pad combo followed by a finishing polish. (orange/cutting polish then white/finishing polish). If you have deeper scratches, not only will you need something more aggressive (both product and pad) but you may need stronger correction, i.e. circular polisher in the hands of a pro.
Work super slowly and have lots of patience to get them out, it takes time.
Gonna try a Orange Pads and SSR 2.5 and work my way down from that. Porter cable takes forever to cut.. Gonna attempt at a faster speed of 6 as well. Just scared that I am taking off to much clear coat..
Speed 6 on the PC is nothing to fear. It doesn't have enough cut to take off enough clear coat to be concerned with, that's why your swirls and scratches are still there.
If the orange/cutting polish doesn't get them all out, you may need to use a yellow pad and a heavy compound on the worst ones, but not the entire car. If you do use yellow/compound, you'll most definitely need to follow it up with a finishing polish on BO.
Good luck.
Good luck.
37
10-17-2020 11:12 AM
delfinparis
11-16-2015 02:26 PM
si_driver
10-01-2015 09:53 AM
