PC vs Flex Orbital Buffers
Probably not, a newer model is due out in a month or two, the Porter Cable 7424XP. It has a slightly bigger motor than the current version and operates up to 6,800 OPM. Unless we have any remaining stock when the new buffer comes in, I don't think there will be any promotions on the PC.
To be honest, there isn't much margin on the tools we sell such it is a competitive market. All said and done we make about $10 on each PC we sell. Our biggest discounts show in our packages we put together, which chances are you'll end up buying most of anyways.
Cheers,
George
Cheers,
George
Probably not, a newer model is due out in a month or two, the Porter Cable 7424XL. It has a slightly bigger motor than the current version and operates up to 6,800 OPM. Unless we have any remaining stock when the new buffer comes in, I don't think there will be any promotions on the PC.
Cheers,
George
Cheers,
George
6,800 OPM vs 9,600 OPM + 480 RPM
4.5 amp motor vs 7.5 amp motor...
It's not much of an upgrade from the current PC. If you're on the brink of buying a PC 7424, it's probably worth holding off a month or so to get the updated model if you don't plan on going for a Flex.
Hope that helps.
George
