Pinnacle Quart Master Foam Gun (ALOT OF PICS)
I already own a Foamaster II Foam Gun, but thought I'd give a try at the the Pinnacle Quart Master Foam Gun.
Basically this is what came in the packaging:
I also might like to add that it comes with a free bottle of car Shampoo too:
You got mixing head:
Foam wand and Deflector:
Siphoning Tube and Screen at the bottom:
Pistol Grip Shutoff:
Siphoning tube attached to mixing head:
Quart Bottle attached to mixing head and pistol grip shutoff:
Foam wand attached:
Basically you have 5 settings on this to fit you needs of how much soap you want it to spit out. Obviously on setting number 5 it will use more soap consumption but you get more suds:
I do recommend your water pressureto be between 40-90 PSI or higher. I have yet to test this baby out comapared to my Foammaster Gun, but it's been raining all day today so I will hold off. While this lets out alot of soap you still want to follow up with two 5 gallon bucks of shampoo of your choice and water, 2 grit guard inserts, and two or more sheepskin wash mitts. This item is great for a pre wash or spraying it and rubbing the paint with a sheepskin wash mitt as you go along, even though I recommend two buckets still.
Foam wand attached:
$60 shipped free. Pretty much the same price if you were going to buy the FoamMaster gun from detailed image or any other car detailing supplier. Both are great foam guns. One thing I noticed about the Quart gun compared to the Foammaster was the build quality. The gun is mostly made of brass and it's a little heavy. But really good quality
Yeah, it's good for doing a pre-wash or something to remove any grit on the paint thus preventing scratches and swirls and less grit in the bucket. You could spray it down with the foam gun as you are wiping it with a sheepskin mit too. But I still recommend a follow up with two buckets.
Victory
17
10-27-2022 04:45 PM
cyberone28
09-23-2015 02:56 PM
Upscale Speed
09-19-2015 12:59 AM
