Help Best way to clean headliner & interior trim
I would use something like Prochem Fine Fabric Shampoo. Thoroughly vacuum first. Spray a little on and agitate lightly with a soft brush. When you scrub with the brush, you are just doing it to make sure the cleaner gets into all of the fibers. You are not scrubbing to remove the dirt/ stain. Then you need to spray some water on the area and extract the shampoo using a shop vac. Make sure you remove the shampoo or the fibers will be more prone to soiling. Also, dont overly soak the area.
Prometheus
General Tech Questions
11-09-2015 01:23 PM
