3M Clear Bra users.
#31
In actuality the windshield glass is designed to not fly apart in a million pieces like the side windows. It is "laminated safety glass" which has a vinyl interlayer film that holds two pieces of glass together. You've seen enough movies with the old baseball bat to the windshield or the terminator trying to break out the windshield. It smashes, but doesn't go kablooey like the side windows. In any regard, don't put anything on it as has been said and replace it when necessary, even if that means once a year in your case.
#32
clear bra on the sport model bumper...
Hi,
For those of you who have installed the clear bra on the Sport model, I am wondering how close the bra cover at the 2 small openings (the 2 fake air inlet) in the Sport bumper? Does it cover all the way to the black plastic pieces? If you have a picture to show it will be great.
Thanks.
Thanks.
#33
I have had 3M on my G35 6spd and on my G37S. It has been a great paint saver!. Try to see and example of the shops work before you have them do the application. Some don't have alot of experience and make a mess of it.
#34
Hi,
Thanks.
Thanks.
#35
ic....Mine is about 1 inch away from the black inserts....and I was thinking maybe they can do a better job.
Hey man. Due to the molding and shape of the dimples, it is nearly impossible for shops to have a perfect cutout for these holes. Mine does not cover all the way to the black inserts, but about half way into the dimple. The guy that installed mine is a great installer and did a great job...looks clean.
#37
I think mine only wraps into those holes a little bit as it is mainly designed to stop rocks flying right at the leading edge. I will look at it tonight. Also, you said these air inlets were fake? No way!
#38
Yes, those 2 small air inlets on the sport bumper are fake. They are made of solid pieces of plastic, no air can pass through.
#40
#43
Hi,
I'm looking at the clearmask AR option, can someone inform me which parts I need to cover that's necessary? Lower/Upper Bumper? Hood Fender Mirrors?
Which kit do I absolutely need?
http://clearmask.com/vehicle_page.php
#44
I just bought an 08 G37 OB,
How much are you charging for the Clearmax AR bra?
Also.. Which parts do you recommend to be covered with the clear bra?
p.s I'm from Canada do you guys ship there? And how much is labour cost generally?
Thanks
Thanks
delfinparis
10-08-2015 06:06 PM
Mattimus
10-04-2015 01:33 PM
