OB badge removal problem?
Old 04-15-2008, 11:07 AM
Graham
Graham's Avatar
So I pulled the "G37," and the "INFINITI" emblems, and there is still the outline in the paint finish from where the emblems came off. Is this going to require wet sanding to remove the outline or can a detailer take it off with a high speed polisher?
Old 04-15-2008, 11:22 AM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
A lil wax and polish and you will be fine and dandy.....
Old 04-15-2008, 11:29 AM
speedracer g37
speedracer g37's Avatar
if you have removed all of the double stick tape, some cleaner wax should help make it look better. the guys here who have debdged will tell you this is normal and will eventually disappear.
Old 04-15-2008, 11:34 AM
Graham
Graham's Avatar
Well i'll hit it again this afternoon with another round of cleaners, polish and wax, but I was bummed to pull off the emblems to see the outline of the letters in in finish. It looks like its part of the paint though, but this is normal? I've debadge many of my cars and never see and outline so pronounced as this but this is my first Infiniti.
Old 04-15-2008, 11:41 AM
MaxToTheG37
No you shouldnt see any evidence of the emblems after you get the glue off and have waxed it.... Detailed Image will be along soon...he will have a for sure answer for you...
Old 04-15-2008, 11:43 AM
Graham
Graham's Avatar
lol.....i'll just wait on hold then until "The Voice" answers.
Old 04-15-2008, 12:01 PM
SkyzDaL1m1T
SkyzDaL1m1T's Avatar
Had the same issue then it went away after a couple waxes and polishes
Old 04-20-2008, 09:19 PM
LAG37
LAG37's Avatar
Help!
i just debadged the infiniti letters of the G
i used the goo gone and the glue is all off.
however the letter imprints r still there and it seems to be a little discolored..
what should i do?
Old 04-20-2008, 09:28 PM
MaxToTheG37
https://www.myg37.com/forums/showthr...hlight=debadge
Old 04-20-2008, 09:31 PM
LAG37
LAG37's Avatar
thanks
Old 04-20-2008, 09:36 PM
LAG37
LAG37's Avatar
the imprint of the letters r still there and its a little discolored.
i tried some of the turtle wax spray and no help...
what should i do?
Old 04-20-2008, 09:47 PM
Former USMC
Former USMC's Avatar
De-Badging and Waxing/Polishing
Greetings,
I also de-badged my black G37S. The emblems left a few marks (imprints and outlines). I used Fine Hand Polish from Griot's Garage applying in a grid manner; followed by Griot's Garage Best of Show Wax...applied with a cotton pad and removed with a microfiber towel...looks great!
I hope this info helps.
Semper Fi
Old 04-20-2008, 09:54 PM
LAG37
LAG37's Avatar
did u order them online?
any other way i can do it?
will a simple buff remove it and make it normal?
Old 04-20-2008, 10:12 PM
LAG37
LAG37's Avatar
bumpppppppppp
Old 04-20-2008, 10:25 PM
infidsg35
infidsg35's Avatar
You have to understand how to remove imperfections from paint before you can know understand what you have to do..
Now you prolly have dull paint or scratches all over the places.. Wax WILL NOT fix this. I have the same problem which I will be fixing this week. I will start with a abrasive compound that will add even more scratches but will even the scratches out. Then I will use a light compound to remove some more scratches but still will look like poop... Then I will use a heavy swirl remover/scratch remover to polish it up.. I will do this several times till all scratches are gone. Then I will use a extreme fine polish to make it perfect
Then you can use sealant and or wax to protect from future...
Just remember you have to polish in steps and going as abrasive as you have to in order to get all scratches out.. Only use the abrasive compounds in the areas that have the scratches. And a RO polisher will help this process out big time! GL!
Quick Reply: OB badge removal problem?
