OB badge removal problem?
Old 04-20-2008, 10:28 PM
LAG37
LAG37's Avatar
will a buff fix this?
Old 04-20-2008, 10:39 PM
LAG37
LAG37's Avatar
are you located in SoCal maybe we can do it together?
Old 04-20-2008, 10:47 PM
infidsg35
infidsg35's Avatar
Sorry im in New Jersey lol...
Ummm just as an example imagine you took a piece of 400 grit sandpaper and swiped your paint. Now you cant just use some polish to get it out. You would have to wet sand it with 600 then 800 then 1000 ect... You have to do it in steps...
So what you first have to do it figure out how bad it is. May take a picture of it and post it. Make sure its in the sun and you see all scratches really well. Then we can better help you out. You only want to sand/compound/polish as abrastive as you have to since you are actually removing clear coat...
Old 04-20-2008, 10:52 PM
infidsg35
infidsg35's Avatar
If its really bad start with this...
http://www.detailedimage.com/Poorboy...r-3-SSR-3-P22/
Then...
http://www.detailedimage.com/Menzern...Polish-IP-P72/
Then finish with...
http://www.detailedimage.com/Menzern...at-Polish-P75/
You may want one of these too...
http://www.detailedimage.com/Porter-...l-Buffer-P110/
Hope this helps...
Old 04-21-2008, 09:53 AM
Former USMC
Former USMC's Avatar
Originally Posted by LAG37
did u order them online?
any other way i can do it?
will a simple buff remove it and make it normal?
LAG37,
Yep, you can order their products on line. Regarding your question about a simple buff...it's hard to determine without first looking at the swirls, scratches, etc before recommending a specific polishing compound and/or buffing. Good luck...
Semper Fi
Victory
17
10-27-2022 03:45 PM
Landshark
01-16-2020 10:25 PM
photocat
09-14-2015 02:32 PM
slawek65
09-08-2015 09:07 AM
Quick Reply: OB badge removal problem?
