Tein SSD Coils
Tein SSD Coils
Finally got to some pics on the drop done Monday- will be taking her in again next Monday for adjustments and setting- Do you guys think I should drop more or this is clean enough ? Thanks
I did 26 3/4" all around so it is a little bit raked but the wheel gap is the same front and back. I used to have the front a little bit hight but decided to try the even look.
You have coils so try it both ways and see which one you like before going for a alignment. Did you get camber kits to fix for excessive camber?
I see you're from t-dot (Toronto?) Home to see you at one of the meets. Our cars are almost exact twins.
Thanks for the compliments and feed back --I will be lowering the front a tad bit -- will like that aggresive look- thinking about spacers, but not sure on sizes, so any input ? -- Also will be installing the JP Kit on soon ( So skylineEX-S-- we might not look like twins anymore ), just got shipment Friday, needs painting first though. -- about the meet, send me a pm or something when you guys have one confirmed, will try my best to make it. I don't know the exact street name off my head, but that graphiti on the wall is at the rear of the Guverment building (it's across from Lobaws) - So if you drive south Jarvis --it's towards the end of Queensquay --
Murkr
09-28-2015 10:45 AM
