Evil Ava Build Thread
#32
That's amazing. You should feel pretty satisfied.
#33
All of which is nothing compared to your boosted project . But when working with Eugene (on a much smaller scale), I get what you're saying.
#35
I remember last year as I engaged Eugene for my tune, thinking I might end up with a car that snarls and snaps at the throttle. Instead what I got was a much better running setup, much smoother than before, with a noticeable but realistic bump in the midrange.
#36
Hey guys! Been a while since I updated! More piuctures, as always. After a little mishap, it came time for a new engine. So this time around, I decided to break the bank a little, and spent a few months doing a lot of work. Progress always hindered by money, you know how it goes! Anyways, without futher ado, the upgrades continue!
First step was getting a junkyard engine and cleaning the living heck out of it and measuring everything. Unfortunately the one i got, looked great on the outside, but was AWFUL inside. whoever had this thing, it came from a Cali car, and good gods, ever hear of an oil cooler??
For comparison, here is the intertior of the engine I was removing from my G.
#37
The next step of course, was cleaning and saving what i could, then getting parts and organizing everything. I didn't take a lot of pictures during the prosecc, but here are a few.
Balancing the crank, of course!
nice and clean head
assembling the heads
new guibo for the driveshaft!
verifying and pairing the pistons, pins, and rods, yay me!
dont forget the upgraded JWT cams.
nice and clean timing covers too.
nice and clean head
#38
Then came the easy (LOL) part. Assembly and blueprinting!
Shiny Pistons
New timing stuff.
nice new wrapped headers.
some assembly required lol. all new alternator, pwer steering, compressor, and other things.
BAM
Shiny Pistons
New timing stuff.
BAM
#39
After getting it all back in, I redesigned my cooling system.
mockup of oil, trans, and radiator.
trans and power steering coolers, thermostats are hidden behind frame rail.
needed a beefier fuel pump relay to run my 3 hellcat pumps. good for 200 amps!
more test fitments
more test fitments
more test fitments
more test fitments
more test fitments
more test fitments
more test fitments
more test fitments
#40
Here is a list of most of the things I've done to the car, as of this January.
Jwt Oil Pan Spacer Kit
Ngk 93026 Spark Plugs
Mahle c31680 rubber Coated Metal Water Outlet Gasket
Dorman 924082 battery Fusable Link/Terminal
Mahle ms19385 multi-Layered Steel Exhaust Manifold Gaskets
Hitachi psp0011 Power Steering Pump New
Gates 23339 Upper Radiator Hose
Mahle vs50493 Valve Cover Gasket Set
Aisin thn014 Thermostat
11340n Alternator 190 Amp
Beck/Arnley 1591065 Fuel Pulsation Dampers
Gates 23340 Lower Radiator Hose
Hitachi str0063 Starter
Uac co11320c Air Conditioner Compressor
Uac Ha112149c Suction Line
Uac ha112085c discharge Line
New Lower Oil Pan
Mega/Amg Fuse, 298 Series
Dorman 60102 Midi Fuse Holder
Gates K071065 Micro-V Serpentine Drive Belt
Design Engineering 010002 Black TitaniumExhaust Heat Wrap
Magnaflow Universal Catalytic Converters 59906
Custom Exhaust Header Set
Setrab Oil Cooler 50-650-7612 6 Series
Hid Bulbs New Osram 66240xnn
Cole Hersee 24213-Bx 12v 200a Continuous Solenoid (For Fuel Pump)
Upper Engine Oil Pan O-Rings
Timing Chain Tensioner Set
Crankshaft Pulley 14868ps
Genuine Driveshaft Flexible Coupling Flex Plate 37511-30020
Replacement Driveshaft Dorman 976-701
Intake Plenum Gasket Set
Z1 370z / G37 Billet Flex Plate
Oem Vq37vhr Oil Temperature Sensor
Oem 370z / G37 Oil Pressure Sending Unit
Oem Vq Lower Timing Chain Crank Sprocket
Oem Vq Short (Cam) Timing Chain
Boundary Engineering Hr / Vhr Billet Oil Pump Cover
Boundary Engineering Hr / Vhr Billet Oil Pump Gears
Jwt C2 Exhaust Camshaft Set - 370z / G37 (Vq37vhr)
Oem Vq Hr/Vhr Main Timing Chain
Wiseco Vq37 Forged Piston Sets - Compression Ratio: 11.0
Brian Crower Sportsman Connecting Rods
Z1 370z / G37 Silicone Front Pcv Hose Set
Z1 370z / G37 Silicone Heater Hose Set
Z1 Aluminum Coolant Bleeder Port - Heater Hose
Oem '09-'12 370z / G37 Heater Hose Clamp
Z1 Vq37vhr High-Energy Ignition Coil Pack
Z1 Metal Hr/Vhr Manifold 3 Bolt Exhaust Gaskets
Z1 Metal 2 Bolt Exhaust Gaskets
Oem Vq35hr / Vq37vhr Connecting Rod Bearings
Arp L19 Head Stud Kit
Z1 Viton Valve Stem Seals
Oem 370z / G37 / Q50 / Q60 Vq37vhr Head Gaskets
Z1 Hr / Vhr Knock Sensor Sub Harness
Z1 370z/G37/Q50/Q60/R35 Urethane Motor Mounts
Z1 Motorsports 370z / G37 Urethane Transmission Mount
Csf 370z / G37 1 Row Triple Pass Aluminum Radiator & Condenser
Oem Vq35hr / Vq37vhr Water Pump
370z / G37 Vq37vhr Rear Timing Cover Oil Gallery Gasket Kit
Z1 Motorsports G37 Aluminum Undershroud
Deatschwerks Vq Drop In Injectors - Injector Size: 1200cc
Spl Bumpsteer Adjustable Front Outer Tie Rod Ends
Z1 370z / G37 / '07-'08 G35 Sedan Aluminum Subframe Bushing Collars
Z1 Motorsports 370z / G37 Adjustable Rear Traction Arms
Spc Performance Urethane Jounce Bump Spacers
Hub Centric Wheel Spacers & Extended Studs - Options: Standard Extended Studs - Size: 5mm
10mm Or 20mm Extended Wheel Studs - Stud Length: 10mm
Z1 Motorsports High Pressure Radiator Cap
Z1 Motorsports 370z / G37 Stainless Steel Brake Lines
Boundary Engineering Hr / Vhr Billet Oil Pump Shims
FI Downpipes
Topgunspeedworks Rotrex Supercharger Kit
Walbro Hellcat 525lph F90000285 Fuel Pump - 3 of these
Hr/Vhr Oxygen Sensor Extension Harness Afr Sensor - Type 4
Vsr 5 Psi Spring For 50mm Gate
8awg Wire for each pump.
Fuel Pressure Regulator, Adjustable, Inline, Return Style
Der-25011 Remote Oil Thermostat, Dual 3/8 In. Npt Female Inlets, Dual 3/8 In. Npt Female Outlets
Der-25791 Remote Oil Thermostat Dual 3/8 In. Npt Female Inlets, Dual 3/8 In. Npt Female Outlets, W/Bracket
R038m- 3810000 | New Magnefine 3/8" Magnetic Inline Transmission Filter
Hps Htsec45-062-Blk Silicone High Temperature 4-Ply Reinforced 45 Degree Elbow Coupler Hose
Denso 2349036 Oxygen Sensor
Four Seasons 74601 Heater Valve - 2 of these
K&N Rc-4780dk Black Drycharger Filter Wrap - For K&N Rc-4780 Filter
Noco Genius2d
50mm Bov Turbo Blow Off Valve V Band Aluminum Weld On Flange Charge Pipe Q Qr
Hps Htsor-300-350-Blk Silicone High Temperature 4-Ply Reinforced Offset Reducer Coupler
Barb Reducer 3/8"X 1/4"X 3/8" Id Hose
Ict Billet -8an Flare To -10an Orb Oring Male Fuel Adapter An920-08-10a
Deatschwerks In-Line Fuel Filter And Housing Kit
Ac Performance Black Aluminum 90 Degree -8 An Male Flare Union Bulkhead Fuel
Quaife Helical Limited Slip Differential +Bearings, Seals, Fluid
Level 10 Bulletproof Transmission Valve Body
Acdelco 13577429 Gm Original Equipment Flex Fuel Sensor
Zeitronix Ethanol Content Analyzer Eca-2 Can Bus
Borla 40659 Mufflers
Derale 13011 Fluid Control Thermostat Kit,Silver
Spl Titanium Rear Camber Arms 370z/G37 Kit
Spl Pro Front Endlinks 370z/G37 Kit
Spl Pro Rear Swaybar Endlinks Kit
Spl Fks Front Lower Arm Bushings (Front) 370z/G37 Kit
Spl Pro Front Impact Bushings 370z/G37 Kit
Spl Eccentric Lockout Kit 370z/G37 Kit
Spl Front Upper Camber/Caster Arms V36 Kit
Hotchkis Sway Bar Set 22441
Deatschwerks 1200cc Injector Set 16mx-06-1200-6
Tein Flex Coilovers Custom Ordered Set
Tein Active Pro Edfc Kitr
Dball2pro Oem Fob Remote Start Integration Kit With Harness
Custom Front Bumper
Custom Side Skirts
Custom Rear Bumper
Custom Fenders
Carbon Fiber Wing
Carbon Fiber Hood (Painted)
Trim Trunk Molding W/ Camera 84810 Jk660
Custom Hub Centric Rings Spacer Od = 70.7mm Id = 66.1mm Aluminium Alloy-4 Rings
Polished Cast Aluminum 90 Degree 3.5"-3" O.D. Reducer Elbow Pipe
Sierra Wireless Airprime Mc7455 3g 4g Lte/Hspa+ Gps 300mbps Module
We826 Wifi Router
Polk Audio Db 652 Db
Polk Audio Db351
Custom Purple Paint (With Jambs)
10amp Wifi Programmable Delay Timer (Each)
Philips Ultinonsport 9005/9006 Led Bulb For Fog Light (Pair)
Cfm Performance 1-1106-3-Fb Billet Valve Cover Breather
K&N Ru-0160
12v To 6v Stepdown Converter
Natika Backup Camera Extension Wire
Pqy 50mm Bov Turbo Blow Off Valve V Band Aluminum Weld On Flange
65mm/59mm Abs Black Wheel Center Hub Caps Set Of 4
Magnaflow 11386
1080p Car Dvr Road Video Recorder Dash Camera Car Driving Recorder
Obd Ii Obd2 16 Pin Splitter Extension
Obdlink Sx Usb Scanner
Dual Port Square Usb 3.0 Panel Flush Mount Extension Cable
Callahan Cds02245
Akebono Sport Brake Calipers (Front) With Custom Paint And Decals
Akebono Sport Brake Calipers (Rear) With Custom Paint And Decals
Custom Tesla Style Android Radio With Systems Integration And Custom Software
Dual Outlet 2.5’ Exhaust Tip
Switchback Drl/Turn Signal Lights With Plug And Resistor
Tail As Turn Rear Led Kit
Center Stop Lamp Alert Flasher Kit
Interior Led Light Kit
Aluminum Subframe Bushing Collar Kit
Unpowered Usb Hub
Professionally Tinted All Windows
Bed Liner (Rhinolining) In Rear Wheel Wells And Under Front Bumper
Stainless Steel Braided Brake Lines
Oem Paddle Shifter Kit
265/35zr20 Michelin Pilot Sport All Season 4
305/30zr20 Michelin Pilot Sport All Season 4 Zp Run Flat
Upgraded Power Steering Cooler Plate/Fin Type
Upgraded Transmission Cooler Plate/Fin Type
Hella Brand Horn 118db Upgrade
Corner Balancing
K&N Air Filter Water/Bug Resistant Cover Ru-5045dk
K&N Air Filter Dryflow
50mm Tial Wastegate With 15 Psi Spring Set
Custom Piping 2.5 Inch Exhaust
Custom Aluminum Splash Shield
Tuning by Eugene Turkov @ Enthusiast Auto Care
This is just a copypaste from my tracking list, so there may be duplicates on here. Not sure. Either way, car is back on the road and fun as ever. Eugene is tuning this engine as well, and hes doing a spot-on job. I am super picky with my setup, and he is working with me on things every step of the way, even comes up with solutions to problems i would have never considered. good guy all around! Y'all seriously should consider him. even has a few CARB approved things, if i remember correctly. (don't quote me on that though.)
New Lower Oil Pan
FI Downpipes
Noco Genius2d
Custom Front Bumper
Custom Side Skirts
Custom Rear Bumper
Custom Fenders
Carbon Fiber Wing
We826 Wifi Router
Polk Audio Db351
K&N Ru-0160
Magnaflow 11386
Callahan Cds02245
Unpowered Usb Hub
Corner Balancing
projectpanda13 (08-20-2024)
Misa (08-21-2024)
#43
I considered painting them, but I wound up liking the clean and shiny new aluminum look. I know they won't stay that way, but at least they look goos for now!
And they stay mostly hidden under the charge pipe anyways, so it would have been a moot point.
