Project Panda
Old 04-08-2024, 01:45 PM
  #271
projectpanda13
projectpanda13's Avatar
So I've been battling with a very odd issue with my idle, fuel trims, VTC readings all fluctuating as soon as it warms up to 158 degree F.
I would also get the P0011, P0021, and P0524 codes. Due to these codes, I was already thinking it was going to be gallery gaskets.
I had plans on checking my oil pressure, after my VVT solenoids checkout to be okay, and even swapped to new one just in case.
I spoke with Martin and he is dealing with this exact issue with a customer out in Europe, he immediately told me to check my wiring plugs for the VVT solenoids and confirm I didn't have it reverse.
Sure enough, I was it incorrect, and sending the signals to the wrong solenoid. Swapped the plugs and this fixed it. I can actually drive the car now, it idles perfectly, fuel trims and VTC readings are all normal.
Because I had the wiring routed at the side versus over the top, I thought the slick sleeve went to Bank1, but its actually suppose to go to Bank2. This image is the incorrect plug orientation.
Old 04-10-2024, 07:08 AM
  #272
projectpanda13
Adding more wheels to the collection. Picked up a set of Volk SF Challenges in very rough condition and unknown specs. It ended up being way too aggressive for the car but hope to rebarrel them.
I need to pull the tires off to measure the width and offset.
Old 04-10-2024, 07:10 AM
  #273
projectpanda13
Also picked up a set of Enkei RP03 in 19x9 +18 and 19x10 +20. Planning to run these while I get my LMGT4 painted.
Old 04-15-2024, 08:49 AM
  #274
SupraOfDoom
SupraOfDoom's Avatar
The volks look sick.
Old 04-16-2024, 09:10 AM
  #275
projectpanda13
Thanks brother. sadly its way too much poke to make it work with my camber setting. Rears were either 11.5' or 12" widths, I haven't pulled the tires off to confirm. Front seem to be maybe a 9.5" with single digit or negative offset.
Old 04-16-2024, 01:35 PM
  #276
SupraOfDoom
Dang. Love the look.
Old 05-13-2024, 10:18 AM
  #277
projectpanda13
I crushed one of the hard lines on the rack during my engine replacement and was leaking power-steering fluid like crazy, but finally had some time to replace it.
Old 05-29-2024, 07:44 AM
  #278
projectpanda13
I never filled up my AC system after my swap and this past weekend was definitely time it was needed. Summers are getting way too hot without AC.
Mattlorentzoe
12-26-2020 06:03 PM
Need 4 Speed
Engine/Intake/Exhaust
76
09-20-2014 11:31 PM
soolman32
MN G CREW
29
10-09-2013 10:23 PM
M.Seyadi
The M - Spot
06-09-2013 06:46 AM
Quick Reply: Project Panda
