Found my unicorn!
Old 08-27-2020, 06:28 PM
  #121
Received 4,726 Likes on 3,531 Posts
I see a tail-light mod in your future. JDM tails, maybe? Or bake them open, doing some custom painting, and a light coat of VHT Nightshades on the inside of the lenses.
Sucks. But like they say, what doesn't kill you is an opportunity to upgrade.
ngolbuff (08-27-2020)
Old 08-27-2020, 07:54 PM
  #122
rotarymike
Moderator in Moderation
rotarymike's Avatar
Just the small backup light portion on the trunklid - not the main lights. AFAIK, the JDM and USDM parts are the same for that part. If they are not, someone let me know the differences because in pictures there isn't anything visible.
I'm pretty sure I'll just get replacements from somewhere - I actually like the look of the stock taillight housings, especially on a black car. It is unique. If anything, I'd tint the clear part red to match the rest of it.
I looked into baking them open / painting when I first started messing with the car, but:
  1. They're plastic welded so no baking - you have to cut them open and pray you can reseal them properly,
  2. I've seen a pair where the inside shiny parts were painted black - actually didn't look as cool as I'd hoped
So, sticking with OEM for now.
Old 09-18-2020, 01:29 PM
  #123
rotarymike
rotarymike's Avatar
<surfaces after almost a month offline, busy with work> Holy carp I need some grease therapy time... the car is feeling unloved.
I did manage to bend my plastic harbor freight ramps - putting the CX5 up for an oil change, they slid a few inches and it accordion-ed the side walls a little. So they're in the NOPE pile now - need to find some metal ramps, or just make some out of 2x12s. Also found my drain pan had a hole, so I guess I'm done with fluid changes until I go shopping. At the rate we're driving the Infiniti won't need it until next year and the CX5 should be good until we start traveling for holidays - if we actually do.
I've got a new alignment that is better, but still not great. Swaybars to install. RJM pedal to install still. Interior is still mostly in my garage. Picked up some carbon flake vinyl and going to test it on the trim above the glove box. SOOO much work on the car to do, so little actual spare time.
Old 09-18-2020, 02:14 PM
  #124
Selym
Selym's Avatar
I did manage to bend my plastic harbor freight ramps - putting the CX5 up for an oil change, they slid a few inches and it accordion-ed the side walls a little. So they're in the NOPE pile nowbox. SOOO much work on the car to do, so little actual spare time.
If your life depends on it, don't but it from Harbor Freight.
Old 09-18-2020, 02:19 PM
  #125
rotarymike
rotarymike's Avatar
True. I usually pop jackstands under the frame rails as a quick safety check - this time I actually jacked the car a little off the ramps and let the weight fully rest on the stands.
Which is what I do when doing any substantial service to the cars - I've got normal jack stands and truck jackstands that lift the car higher. But for oil changes/messing with front bumper internals, I used the ramps to get myself just a bit more.
I'm trying to come up with a way to cut a continuous ramp on stacked 2x12s. I think that is ultimately more solid than a steel or plastic ramp, and cheaper than the solid raceramps by a good bit.
Old 09-18-2020, 03:02 PM
  #126
RMB5190
RMB5190's Avatar
I got my ramps from Rock Auto and while they are sturdy and show no signs of giving, I still put jacks under the car for reassurance.
Old 09-18-2020, 04:44 PM
  #127
Hey, I did an oil change today too! On the wife's Forester.
About 2 or 3 years ago, I bought a pair of Race Ramps for the G, but use them for all my cars. Easiest damn ramps I've ever used. Wide, sturdy, it's all good.
Old 09-19-2020, 07:16 PM
  #128
rotarymike
rotarymike's Avatar
I'm getting too much side-eye from the wife when I suggest those (at $300 for the set). If they had some that didn't involve the word 'race'...
Old 09-19-2020, 07:58 PM
  #129
Totally understand. Buying nonessential car stuff when property taxes come due. Awkward.
Old 09-20-2020, 12:23 PM
  #130
SwiftKit
SwiftKit's Avatar
Nice G, how much did the dealer charge for that lip?
Old 09-21-2020, 07:28 AM
  #131
rotarymike
rotarymike's Avatar
Thanks!
The lip came from ebay, actually. Just make sure when you're looking at them that you get a polyurethane one and not a fiberglass one. About $150 shipping IIRC. Unpainted, unprimed, so there is some work to be done - if you don't have a black car spending the $ for the dealer pre-painted one might be cheaper than body shop time to paint.
SwiftKit (09-21-2020)
Old 09-28-2020, 05:04 PM
  #132
rotarymike
rotarymike's Avatar
New back-up lights coming from amazon. Didn't like any of the commercial options (IE, the one) and I thought long about removing the reflector entirely and replacing with a panel LED, but IMHO not worth the effort. Also white LEDs typically are coated with yellow so it would look weird.
If the weather is promising, maybe I'll see where I put the Skyline badge and get that on the trunk.
Old 09-28-2020, 07:46 PM
  #133
ngolbuff
ngolbuff's Avatar
Link for your lights? What did you end up going with?
Old 09-28-2020, 08:33 PM
  #134
rotarymike
rotarymike's Avatar
oem, or OEM replacements.
For Infiniti G35 Sedan 07-08/G37 Sedan 09-13/G25 Sedan 11-12/Q40 Sedan 15 Inner Tail Light Assembly Inner Pair Driver and Passenger Side
Amazon Amazon
Ill post reviews once they’re in.
Old 09-30-2020, 02:08 PM
  #135
rotarymike
rotarymike's Avatar
New reverse lights came today. Pleasantly surprised at packaging, new in box DEPO brand. Somewhat different than OEM - first notice is that the rear plastic part is chrome plated everywhere, including the back.
Look good, have the trim seal and the adhesive on the back. Friday I'm off so maybe then.
Quick Reply: Found my unicorn!
