DuuMaa's Build Thread
#136
Its funny how most car guys are also gun guys. Two expensive hobbies that make it difficult to properly proportion funds lol.
I'm in California so we get 91 in place of 93 which was the major reason for going flex for me. But I'll also be running 91 for the majority of the time. I'm going to visit Seb at Specialty-Z for my flex install and tune.
I won't be running an extra fuel tank however.
I'll personally be running a Zeitronix flex fuel sensor along with the Zeitronix ECA-2 ethanol content analyzer. I'm not going to be installing a gauge at this time. That'll happen when we install the TT Kit next year. We'll also be installing 1000cc fuel injectors and perhaps a larger fuel pump if required.
That seems like the way to go. The gauge isn't necessary I agree, just something for me to add in for monitoring. 1000cc injectors should be enough as long as your motor isn't built, we maxed out 1000's at about 14psi on another car. Upgraded to ID1700cc's, what injectors will you be running when you go flex? I was going to throw in some stock GTR injectors, I literally have a mountain of them laying around here. For the pump, DW makes a drop in pump that I was looking at getting to help out the surge tank.
If I may ask, if your going with the innovate gauge why not go with the full on ECF-1? I went that route and re-purposed the fuel pressure sensor as a oil pressure gauge since it's typically the Achilles heel of our engine. Obviously for my build being NA it made the best option to cover all the bases, but I'm trying to see why others, like the two of you, go different routes and I'm sure in the future others would like to know the thought processes we went through.
PhoQ, yea their stuff is top notch in my book. I was considering running their surge tank and mounting it in the trunk as your right: they can be loud. But I'm also considering dropping the extra cash and just going with CJM's road race in tank setup (if it will fit the G tank, which it should). I've already had the right hand turn fuel starved problem twice now. Once the car shut off as normal, on an other instance i felt it go and let off the gas; I think having larger rails saved her on that situation.
I wouldn't see why the CJM road race setup wouldn't fit. I wanted to get the car squared away for when I do decide to take it to the track, I would have tackled the major issues first. Fueling being one of them.
#137
Originally Posted by PhoQ
Yeah, there are a lot of people into the same hobbies. If it weren't for the guns I have my car would have been turbo'd already. That blows, the ethanol should help you get safer numbers than what 91 can do. The tank was just for the future so I wouldn't have to do labor 2 times and I won't have issues with starvation when I bring it to a track.
I'll be going with the 1000cc Bosch injectors right now. We had originally planned to do 600cc but then decided to just do the 1000cc right now. As far as the pump, the car is low mileage and the stock pump should be fine but we might just swap it for peace of mind.
#138
I don't know if this would help in your situation but with the mazdaspeed I used to drive I tuned right to the edge of detonation then would mix 1 gallon of e85 into my gas tank every fill up and it would prevent the knock but let me basically maximize my 93 tune. We all ran tons of different ethanol mixes and just adjusted injector scaling to compensate. Anyway where I am headed is what if you just got an aggressive 91 tune and mix in a gallon of e85 every fill up? Would compare to 93 without needing any extra fueling help
#139
I like that idea of mixing in a gallon of e85 but on rare occasions, a family member has driven my car and I don't want to risk them not filling in the required e85. Secondly, I use the car quite a bit and don't want to end up somewhere I'm low on gas and don't have a gallon of e85 available and I'd rather not drive around with a gallon in my trunk all the time. Also, I'd have to do the fuel upgrades when I switch to TT anyway so all I'd really save would be the $400 for the Zeitronix hardware.
#140
The single gallon is for wide open throttle detonation protection, daily driving with just 93 wont hurt. I assume the programs used for tuning allow the computer to retard timing based on any detonation seen? I have not played with the tuning software for these cars.
#141
Exactly, if California had 93 octane I might even had skipped flex fuel and just ran 93. I'm not going to be running really high boost because I'm not going to build the motor. 500-550whp should do it for me. I'd honestly be happy with less and would've gone with the Stillen SC setup if it wasn't such a compromised system. So I'll be going with the Fast Intentions TT system. How about you Kevin, which TT system are you looking at?
You'll probably run out of injector at that power level. 1000cc's should be fine for that much power. I would look into the pump, its cheap and will be one less thing to worry about when boosted.
#143
Originally Posted by DuuMaa
After waiting to hear back from Project Mu on the front rotors and not getting a good timeline, I ordered the DBA T3 5000 slotted rotor. I will however still be going with the Project Mu brake pads and rear rotor.
#145
Decent sized update:
Got the brakes installed and everything feels great. Car stops more aggressively, good upgrade.
Brakes Installed, nothing cool here... yet.
So I came in on my day off to get these things installed, had some free time so I decided it was a good opportunity to test fit some wheels we had laying around.
Put my rear wheels on the front with the specs are 19x10.5 +38 & 285/35 tires on.
Now onto the cooler options I had. Jotech/ADV1 GTR Specific wheel.
20x10.5 +30ish w/275/35-20
TE37SL 18x10 +30 w/ Nitto NT555R 305/40-18. Don't mind the curb rash, it was from one of our GTR's that wrecked at the track.
ShuuraRG (09-09-2016)
#148
Thanks for posting the fitment details on those drag radials! That's the same tire size I've been considering and those wheels give me somewhere to start when I start shopping!
Incidentally, I've got Walbro 255 LPH pump that I'll be replacing with a DW300 that I got in a sponsorship deal. Let me know if anyone is interested in a Walbro pump.
#149
Thanks, I am trying to do different things that what the "normal things" that other people are. The goal is to have my car set up for road course. HAHA, mortals, I am included in that statement as well. I'm just trying to get by in the car scene.
Nice! I was actually going to drop in a DW300 and go with a Radium external surge tank for my fuel system needs. Mounted where the spare tire is.
#150
Thanks, the +30 offset is a bit tough to fit, but the TE37's also come in a 18x10 +40 which should clear without issues. That would be the size I will end up going with.
With my rear fenders being ~1-1/4" wider than stock, the +30 offset shouldn't be a problem at all. That should actually work pretty well for a drag set-up since it won't be too aggressive. I'm currently running 20x10.5" +37 (with 305/25R20's) in the rear along with 12mm spacers. And with just -1.5° to -1.7° camber I still have plenty of clearance. That's about a +19mm offset on a 10" wide wheel.
Yeah, the DW300 is a nice direct bolt-in pump. It's a good match for my 750cc injectors where I think the Walbro was a bit undersized.
