My Mod + Dyno Log
Old 07-04-2014, 10:00 PM
  #181
alfredo24pr
alfredo24pr's Avatar
Originally Posted by G37Genova
Only 8 and half away!!!!!!!!! with a tune you'll be over the 300 whp hill
yep. can't wait. so far an estimated 37.5 HP and 17.87 TQ gain to the wheels
Better not Alfredo, you've been really providing some valuable step by step additions, can't go against that at this point.
Really appreciate you taking the time to document everything and adhering to your own personal mantra of noting each individual mod & it's true pros &/or cons. Your numbers are climbing nicely, looking forward to the Motordyne review
Thank you. Glad to contribute and share.
Im also looking forward to reviewing the Motordyne. Hoping to install it sometime next week.
G37Genova (07-07-2014)
Old 07-06-2014, 02:58 PM
  #182
Redfire32
Ginger ninja
Redfire32's Avatar
Can't wait for the M370 review!! I'm holding off on my mods until I see your results man! Thx for validating everything for all of us. Probably one of the top 5 threads I've read.
alfredo24pr (07-06-2014)
Old 07-07-2014, 05:30 PM
  #183
d0m0
d0m0's Avatar
tremendos numeritos!!!! aqui un PR member xD
Old 07-07-2014, 08:21 PM
  #184
BeachmanQ60
BeachmanQ60's Avatar
Numbers after tune
As you can see I increased a little more but with already great numbers I didn't expect much more from my tune.
Old 07-07-2014, 08:46 PM
  #185
alfredo24pr
gracias! de los pocos que hay..
looks great. Any idea of the numbers when stock?
Old 07-14-2014, 08:45 AM
  #186
alfredo24pr
Installed the M370
car feels lighter and a bit more responsive. easier on the throttle going uphills and changing lanes. haven't tested it that much, but pretty happy with the mod. hopefully it will turn out better after getting tuned.
sound is sharper and less boggy when accelerating, although at full throttle, idle, and start up it's still the same (at least to me).
and yes, the engine cover fits perfectly. only problem is that the middle screw is not used and you need an extra one since they all use the same 4.
The OEM manifold has 3 same screws (two for the top and 1 for the middle) and 2 different ones for the bottom, for a total of 5.
PongSanity (07-14-2014)
Old 07-14-2014, 11:57 AM
  #187
PongSanity
PongSanity's Avatar
update that signature pleighboi! looking forward to that dyno run... dyno-ing mines labor day weekend...DOMO
Old 07-14-2014, 03:22 PM
  #188
alfredo24pr
Almost forgot about the signature. Thanks!
Im also looking forward to the dyno run because after that I'm ready to tune.
Old 07-17-2014, 09:09 PM
  #189
alfredo24pr
M370 sucks
dyno'ed the M370
loss of power, but worst of all, waste of money.
deciding whether to uninstall. going to give motordyne the benefit of the doubt and will be contacting them to see what could be wrong.
Old 07-17-2014, 09:14 PM
  #190
Received 4,726 Likes on 3,531 Posts
Originally Posted by alfredo24pr
dyno'ed the M370
I suspect Motordyne is going to tell you to get the car tuned before making any decisions. Probably good advice.
Still... that's disappointing, Alfredo.
Old 07-17-2014, 09:29 PM
  #191
alfredo24pr
I was doing so well with the other mods..and now this
Also, how will I know that the M370 is working better than the stock manifold after tuning with the M370? I have nothing to compare with.
Old 07-17-2014, 10:01 PM
  #192
Received 4,943 Likes on 4,176 Posts
That's too bad Alfredo, a bit of a buzzkill for sure
Do you think you'll tune or go back to your OEM manifold?
Quite a quandary
Old 07-17-2014, 10:50 PM
  #193
Redfire32
Ginger ninja
Redfire32's Avatar
SOB I was waiting on your results to get my m370......but I found one on the private classified section for a deal that had only been used a month. Pulled the trigger too soon apparently. Installed it last night. I felt like it made the engine sound a bit deeper and I really liked that. As far as power goes I wasn't certain it had gained all that much, but the car sure does fly so it's difficult to tell. I haven't found a dyno guy in town yet (I'm located in NE Arkansas) but I think it's time. Hopefully the mod will end up workin out for both if us. If not I figure there will be a couple great deals on a FS thread soon.
Old 07-17-2014, 10:54 PM
  #194
Redfire32
Ginger ninja
Redfire32's Avatar
I guess I'll keep it on and hold on to the stock mani. Once I get the FI LTH's in and installed I'll get a uprev n see what the tech says about both intake options. Sad sad sad results tho. I feel your pain Alfredo
Old 07-17-2014, 11:26 PM
  #195
alfredo24pr
Quite a quandary
will decide after motordyne responds to my email. Sucks that I could have used the money for a tune instead. very disappointing...
maybe an ECU reset would help?
Good thing I kept the stock manifold. Hope it works out a lot better for you and hopefully I can "fix" mine.
Quick Reply: My Mod + Dyno Log
