Vendor TUNERZ STORE | SPC Performance Front & Rear Camber Kits G35/37 Sedan & G37 Coupe
SPC Camber Kits G37
These front upper control arms will give you -1 degree to +1.0 degree caster change and up to -2.5 degrees to +2.5 degrees camber change. Simply replace the OE front upper control arms and dial in your suspension angles with our patented sliding ball joint and caster plate. Whether you want to tune your suspension for the ultimate in handling performance, minimize tire wear or easily move back and forth between the two settings, these are the arms to get the job done.
Front Adjustment range:
Camber: -2.5 degrees to +2.5 degrees
Caster: -1.0 degrees to +1.0 degrees
Installation time: .6 hr/side
Required: 1 kit per axle (72130)
The 72280 Adjustable Rear Control Arm and Toe Kit offers major alignment angle adjustments for Infiniti M35.45 and G37 sedans and coupes. The fully adjustable camber arm provides +/- 3.0 degree of change and the toe kit +/- 1.5 degree. Your alignment needs are met whether adjusting a stock height or lowered Infiniti.
**This kit uses a larger cam washer to achieve greater adjustment than the OE toe cam provides. In order to take advantage of full toe adjustment mark the area to elongate the existing toe slot with template provided. **
We have a few kits in stock, so pm us for forum member pricing.
