Special SPL Front and Rear Endlinks-Now Available!!!
Send me a PM for your order.......
Front Endlinks
SPL FE Z34
Description:
Our endlinks feature massive 3-piece FK 1/2" bearings to provide the highest load capacity for use with stiffer aftermarket sway bars, and custom made high misalignment studs that offer extreme articulation capability (65deg) to prevent the endlink from binding when used with different adjustment holes on aftermarket sway bars.
Our endlinks are also length adjustable to eliminate preload on tjhe sway bars, which can result from uneven settling of springs or uneven suspension heights from corner weighting.
Rear Endlinks
SPL RE Z33
Description:
Our endlinks feature massive 1/2” bearings to provide the highest load capacity for use with stiffer aftermarket sway bars. High misalignment bearings offer greater misalignment capability (65deg) than stock endlinks to prevent the endlink from binding when used with different adjustment holes on aftermarket sway bars.
Our endlinks are also length adjustable to eliminate preload on the sway bars, which can result from uneven settling of springs or uneven suspension heights from corner weighting.
Front Endlinks
SPL FE Z34
Description:
Rear Endlinks
SPL RE Z33
Description:
