Vendor Hotchkis Swaybar kits G37 and G37X Applications.
Hello Guys,
We have these in stock ready to ship. These are one of the best upgrades you can do for handling on the G37. Hotchkis is one of the leaders in suspension products. I have been selling there Hotchkis parts for a long time. Always have nothing but great things to say about the products. Check the listing below.
Hotchkis sway-bars 07+G35,G37 and G37S
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your G37 or G35
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37,
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
Install instructions for G37 coupe/07+G35 sedan:
http://www.hotchkis.net/_uploaded_fi...011810file.pdf
07+G35X/G37X (AWD Model) Pm for Best Price.
Enhance the cornering performance of your G35X/G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets Item# 22443 fits 08+ G35X, G37X AWD Models Only. RWD Models use item 22441 08-10 Infiniti G37X (AWD) 08-10 Infiniti G35X (AWD) Features: • Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar. • Lightweight, Durable 1.125" (28mm) Tubular Rear Bar 3 Way Adjustable • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable anthracite powder coat. Benefits: • Brings handling excitement to your G35X • Dramatically improves steering and chassis response • Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness • Easy bolt-on installation. Videos
We do have Hotchkis rebuild kits available also. Includes 4 bushings.
B2 Auto Designs
We also have in stock to ship:
Eibach Anti-Roll:
Eibach - Anti-Roll Kit (Adjustable/32mm Front/ 29mm Rear), For Infiniti G37. Front Sway Bar Is Tubular And 2 Way-adjustable/ Rear Sway Bar Is Tubular And 3 Way-adjustable.
Cusco swaybars
Cusco - Sway Bar (Front) Hollow 28mm
Cusco - Sway Bar (Rear) Solid/25mm
Tanabe swaybars
TANABE FRONT 30.4mm Swaybar
TANABE REAR 25.4mm Swaybar
Whiteline swaybars:
Whiteline Front 33mm Heavy Duty Adjustable Sway Bar Infiniti G37. 2 Point Adjustable:
Whiteline Rear 24mm Heavy Duty Adjustable Sway Bar for Infiniti G37.
3 Point Adjustable.
We have these in stock ready to ship. Fast shipping with friendly service. Please pm me or call us 813-787-4075 for best pricing.
Thanks
Charles
Features:
Benefits:
Specs:
B2 Auto Designs
Eibach Anti-Roll:
Cusco swaybars
Tanabe swaybars
Whiteline swaybars:
3 Point Adjustable.
Thanks
Charles
We also have the Eibach swaybar kit in stock.
Eibach 32mm Front & 29mm Rear Anti-Roll-Kit for 09-13 Infiniti G37 Sedan.
Please pm me for pricing.
Thanks
Charles
Thanks
Charles
