Vendor BC Racing Coilovers offered at B2autodesigns
Old 01-25-2012 | 07:59 PM
b2autodesigns's Avatar
b2autodesigns
Hello Guys,
Black Friday Deals: Message me for pricing.
We are a direct deal of BC Coilovers. These are a great coilover set up. Great pricing for a really nice product. I liked these so much I even but them on my own project car
Check link for full build:
http://g35driver.com/forums/other-ca...4-me-play.html
Customers G37 lowered on BC BR coilovers:
Here is alittle info on there product:
General
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical:
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
Applications:
G37 coupe /sedan RWD
G37 coupe /sedan AWD.
BR-Type
BC BR coilovers with Swift spring upgrade.
We also offer package pricing. BC Coilovers and SPC rear camber kit w/toe bolt. Message me for package pricing.
Please pm me or call us 813-787-4075 for best pricing.
Thanks
Charles
Coltrane1 (03-13-2017)
Old 01-25-2012 | 08:13 PM
borderline's Avatar
borderline
Pm me please. G35x 2008 sedan. Shipped to 04945
Thanks
Old 01-30-2012 | 06:50 AM
b2autodesigns
The ISC coilover sleeves help protect your coilovers during harsh winter months. Sold as a pair. Two sizes 300mm and 370mm. Fits most coilovers.
$59.95 shipped for a pair.
Link to more information and to order:
http://www.b2autodesigns.com/index.php?cPath=13_24_1367
Thanks
Charles
Old 02-02-2012 | 08:55 AM
b2autodesigns
bump
Thanks
Charles
Old 02-04-2012 | 01:17 PM
b2autodesigns
BC Coilovers and SPC camber kit packages. Message me for package pricing.
Thanks
Charles
Old 02-04-2012 | 01:30 PM
pauliewalnutzz's Avatar
pauliewalnutzz
Give me your worst price shipped to New York 10314 BC Coilovers and SPC rear camber kit 09 G37X
Old 02-04-2012 | 09:52 PM
iriedence's Avatar
iriedence
PM Price shipped to 92023 please. BC Coilovers and SPC rear camber kit. '08 G37s coupe.
Old 02-05-2012 | 09:25 AM
b2autodesigns
Both pm sent. Thanks guys.
Charles
Old 02-05-2012 | 11:30 PM
tjf37's Avatar
tjf37
PM for the coilover and camber kit shipped to 85142. Thanks!
Old 02-08-2012 | 03:02 PM
b2autodesigns
pm sent
Thanks
Charles
Old 02-08-2012 | 03:22 PM
Corvettekid's Avatar
Corvettekid
Can you send me price for coil overs and camber kit shipped to 11545. And can you also give me a price for each seperate? Thanks very much
Old 02-08-2012 | 11:32 PM
Princew69's Avatar
Princew69
how much for coilovers shipped to 21113, thanks
Old 02-12-2012 | 12:39 AM
b2autodesigns
All pm sent
Thanks
Charles
Old 02-14-2012 | 03:06 PM
b2autodesigns
All pm sent
Thanks
Charles
Old 02-14-2012 | 03:30 PM
SmoovE's Avatar
SmoovE
PM price of coilovers to 11236
thanks
