Sponsor TUNERZ STORE | G37 White Line Adjustable Sway Bars & Rear endlinks--RWD Only
Early Black Friday sale through November 14th 2011.
Whiteline Sway Bars
The fitting of bigger Whiteline wwaybars is still the best dollar for dollar handling improvement you can make. Cornering loads are spread more evenly across the tyres delivering more grip and frankly, that’s what it’s all about. You also get improved tyre wear as your tyres stay flatter and more upright. Comfort improves because your car sits flatter through bends meaning less movement inside the vehicle. Whiteline swaybars are manufactured using the finest grade spring steel. They are powder coated and supplied with high performance polyurethane mounting bushes in a DIY kit form, ready to simply bolt on.
Part Notes
Replacement type
2 point adjustable
Front: 27mm adjustable (BNF41Z )
Part Notes
Replacement type
3 point adjustable
Rear: 24mm adjustable (BNR37Z )
Sway bars and endlinks maybe purchased separately individually. Please feel free to contact via PM or call (502) 718-1700 for best price. Several sets in stock ready for immediate shipment!! Does not fit AWD..
White Line Sway Bar Conversion Chart
Whiteline Sway Bars
Part Notes
Replacement type
2 point adjustable
Part Notes
Replacement type
3 point adjustable
Here is some additional information from Whitelineon the sway bars and the stiffness.
All our sway bars are solid and yes a two hole adjustment is two settings and a three hole is three settings of adjustment.
As for % of stiffness we do not have information on each hole as on each different sway bar we make the increase would be slightly different as some arms are longer etc plus the fact they attach in different parts of the suspension.
A slight way to understand would be that say a 24mm on the middle hole of three hole adjustment is a 24mm bar stiffness.If it was to be on the hard setting it would be just under the stiffness of a 25mm sway bar.If it was put on the softer setting it would be around close to a 23 mm sway bar.
This chart attached is not 100% accurate it is very close but some swaybars will be slightly different due to the appplication
As you probably already know your sway bars would have been hollow from factory hence why the swaybars we are making in solid will not be really that much larger as being solid they will be allot stiffer than a hollow bar of the same diameter.
superjoey
31
03-22-2023 11:56 PM
SkylineG
Intake and Exhaust
13
10-03-2018 07:56 PM
