If I get these for a stock 2011 G37x sedan, would I have to get anything else (spacers, shocks, to be able to install these? Or can i install them w/o any other mods?
Whats the price for them shipped to 80021?
I also plan to get Hotchskis sway bars in a few months. Would the Swift springs and Hotchskis be compatible? (Pardon my ignorance here, I am not too knowledgeable about suspensions)
Price is $340 shipped and 2 sets available.
The swaybars will compliment the springs and will work together very well.
Let me know if you want to place the order
Yea I just saw, thanks. I need an awd review. Now someone has gotta want them for x right I am debating bc coils vs swift springs. I hear so many mixed things about bc makes me sad that is the only choice. What is the drop w/ x sedan lou?
1.3" Front, 8kg/mm spring rates
1" rear, 7.4kg/mm spring rates
Don't let the spring rates scare you, The 370z SPEC R springs are even stiffer at ove 10kg and when i test drove them on my customers cars, they were great and not at all too stiff, just slightly stiffer than the OE ride. Also, the G is a heavier car compared to the 370z so i would say the ride will be even better for the G.
Sport springs are linear with top portion of the springs are progressive type to act like helper springs so they won't get stiffer unless you put load on them. The harder you corner, the stiffer they get just like the KW V3.
If the ride height is ok with you, you won't be disappointed with the Swift springs. Very street complaint. Hope that helps
mine have been ordered and Ill post a review after install. The only question is when I will have time to install.
thanks
Lou
Would these springs work with stock shocks?
Really no other mods you'll need, Just like he answered above^^, Swift designed them to work with your OEM shocks. The only time i would suggest to change your shocks is when they are blown
As for spacers, if you want your wheels to be more flushed to the fender then yes but its not necessary to add them. It will look better though if you do.
What about alignment? Are we able to get back to stock specs with these springs installed or is a camber kit required?
I'm interested in hearing if we need camber kits as well. To my knowledge, any drop more than an 1" should need one...am I off base here? I'm
Interested in purchasing as well..$340 seems a tad steep though.
