Special Hotchkis Sway bars 08-10 G37,G37S,370Z,G35
<style>#Photo_List { position: relative; display: block; }#Photo_List ul { margin: 0pt; padding: 0pt; list-style-type: none; width: auto; }#Photo_List ul li { display: block; float: left; }#Photo_List ul li a img { padding: 1px; border: 1px solid rgb(255, 255, 255); }#Photo_List ul li a:hover img { border: 1px solid rgb(0, 0, 0); }</style> <table class="Product_Page_Table_1" width="100%" align="center" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td> Sport Sway Bar Set, 08+ 370Z, G37, G37S, G35
Description:
Enhance the cornering performance of your 370Z or G37 with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets
Item # 22441 RWD Models Only! Does not fit All Wheel Drive models.
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.125 (28mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your 370Z, G37 or G35
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 28.5mm (Ø1.125") Hollow 3 Way Adjustable
+130, 185, 260% Stiffer than Stock G37,
+15, 40, 75% Stiffer than stock G37S
+60, 100, 155% Stiffer than stock G35S
Effective 8-17-2010 the size of this rear bar has been changed from 27mm to 28.5.
Videos
G37 Stock VS Hotchkis Sway Bar Upgrade Comparision Video.
370Z Stock VS Hotchkis Sway Bar Upgrade Comparison Video
Front Sway Bar Install Video
Rear Sway Bar Install Video
<form action="/sport_sway_bar_set_08_370z_g37_g37s_g35.html" method="post">Sport Sway Bar Set, 08+ 370Z, G37, G37S, G35. For our unbeatable price PM us, or go to Hotchkis Sports Sway Bar - JEB Performance, Inc. - Thousands of after market tuning parts for less
Application Guide:
09-10 Nissan 370Z
07-10 Infiniti G35 Sedan 4dr
08-10 Infiniti G37 Coupe
08-10 Infiniti G37 S Coupe
Downloads:
Installation Instructions
</form>Additional Information:
</td></tr></tbody></table>
I am pretty sure they forgot to add G37S Sedan. But on Monday I will double check with Hotchkis and update the specs.
Thank you for noticing.
PM US for better price. THROW US ANY NUMBER "A VALID QUOTE OR OTHER WEBSITE OFFERS" !!!!!! WE WILL NOT BE BEATEN BY ANY OTHER VENDORS, OFFERING YOU BETTER PRICE THAN OURS!!!
