Special StopTech rotors
#62
Which rotor is right one for me?
To put in simple terms, it all depends on your local weather. Extremely hot geographic area with little rain use drilled rotors. Extremely cold and wet to snow geographic areas recommended use of slotted rotors. Not so cold and have little bit of both from hot and wet use drilled and slotted rotors are recommended.
Drilled rotors if run on extremely cold weather like north pole after 20'000 miles of use may see cracks on the edges of the drilled holes.All drilled rotors from Stoptech are diamond cut. After the rotors wear out may cause cracking.
Slotted rotors helps wipe water away from the rotor, however does little for dissipating heat.
Slotted or Drilled Rotors will cost less than your OEM brake rotors at the Dealer. Less vibration under braking. Very quiet and smooth braking.
Easier than you thought Right? So PM us for your brake rotors NOW!!!!!!!
C-TEK Standard Rotors
C-Tek brake rotors offer an alternative replacement rotor and are available in a wide variety of applications both import and domestic. All C-Tek rotors feature an double-disk ground finish.Double Disc Ground
Centric premium rotors feature a double disc ground, taper free finish. Double disc grinding ensures parallelism, eliminates run out and provides near perfect disc thickness variation (DTV). Double disc grinding leaves a non-directional finish on the friction surface area for more effective pad-rotor break in. This special finish also provides quieter and smoother stops.
C-TEK Standard Rotors for G37 Base brake system - front MSRP $98.75
C-TEK Standard Rotors for G37 Base brake system - rear MSRP $84.95
C-TEK Standard Rotors for G37 Sport brake system - front MSRP $95.65
Power Slot Slotted Rotors
Power Slot is Centric’s performance division focusing on entry level brake upgrade solutions. Power Slot pioneered direct fit performance rotors for trucks, SUVs and severe duty vehicles, delivering superior and reliable braking even under hard driving conditions. Excessive heat can cause resins in your brake pad to vaporize or “outgas.” As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance.
Power slot Slotted Rotors for G37 base brake system - front right MSRP $189.71
Power Slot Slotted Rotors for G37 base brake system - front left MSRP $189.71
Power Slot Cryo Treated Slotted Rotors for G37 base brake system - front right MSRP $219.71
Power Slot Cryo Treated Slotted Rotors for G37 base brake system - front leftMSRP $219.71
Power Slot Slotted Rotors for G37 Sport brake system - front right position MSRP $218.00
Power Slot Slotted Rotors for G37 Sport brake system - front left position MSRP $218.00
Power Slot Slotted Rotors for G37 Sport brake system - rear right position MSRP $169.29
Power Slot Slotted Rotors for G37 Sport brake system - rear left position MSRP $169.29
Premium Cryo Treated Rotors
Centric Premium black rotors feature Original Equipment specifications and production processes. These Centric rotors are manufactured to meet QS and ISO Quality System Standards.
Centric premium rotors utilize an Electrocoating finish that provides long lasting corrosion protection. E-coating is a superior electro-statically applied finish designed to withstand 400 hours of salt water exposure without rusting. Phosphate finishes utilized by other manufacturers provide only minimal protection from the elements; these finishes are generally only effective for the shipping and storage portion of a rotor’s life. The addition of heat and moisture eliminates the effectiveness of phosphate finishes resulting in immediate corrosion once installed in the vehicle.
Premium Cryo Treated Rotors G37 Base brake system - front MSRP 164.56
Premium Cryo Treated Rotors G37 Base brake system - rear MSRP 121.00
Premium Cryo Treated Rotors G37 Sport brake system - front MSRP 233.20
Premium Cryo Treated Rotors G37 Sport brake system - rear MSRP 165.00
SportStop Drilled and or Slottled Rotors
Cross drilled or drilled and slotted brake rotors prevent glazing of the pads, add bite and improve wet and dry braking performance. The addition of high performance street pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. Motul RBF600 brake fluid increases both wet and dry boiling points and prevents boiling even under the most severe operating conditions. Good for street and autocross. Not for extended track sessions.
Most SportStop performance rotors feature our special Power Alloy metallic compound.
ONLY AVAILABLE FOR G37 WITH SPORT BRAKE SYSTEM
SLOTTED
Front right MSRP $190
Front left MSRP $190
Rear right MSRP $180
Rear left MSRP $180
SLOTTED & DRILLED
Front right MSRP $205.71
Front left MSRP $205.71
Rear right MSRP $178.57
Rear left MSRP $178.57
Only offered from JEB Performance when you buy any StopTech Brake Rotors from us. We will inlcude 14.oz bottle of brake cleaner absolutely free. So you can always run your rotors with out gunk, dust, and rust. A $10 value absolutely FREE. Limit one per pair, a courtesy from Centric Parts.
14 Oz. Ultra-Low VOC Brake Cleaner
Degreases & Derust quickly and can be used without disassembling the brake unit.
Price based on US Domestic shipping only
SLOTTED
Rear left MSRP $180
SLOTTED & DRILLED
#69
DRILLED
Rear left MSRP $180
SLOTTED & DRILLED
DRILLED
Rear left MSRP $180
SLOTTED & DRILLED
