Special K-Sport Big Brake Kits
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
FRONT BBK:
13 Inch Procomp Front Big Brake Kit -
- 8 Piston Aluminum calipers
- D.O.T. Compliant Stainless steel brake lines
- Machined aluminum hats
- Carbon steel brackets
- 330mm (13") large ventilated discs (17" wheels required)
- High quality Ksport SC5 street brake pads (RC1 race pads available for additional cost)
MSRP: $1700
14 Inch Procomp Front Big Brake Kit -
- 356mm (14") large ventilated discs (18" wheels required)
MSRP: $2200
15 Inch Procomp Front Big Brake Kit -
12 Piston Aluminum calipers, D.O.T. Compliant Stainless steel brake lines, Designed to utilize OEM master cylinder, Machined aluminum hats, Carbon steel brackets, 380mm (15") large ventilated discs (19" wheels required), High quality Ksport SC5 street brake pads (RC1 race pads available for additional cost)
MSRP: $3200
16 Inch Procomp Front Big Brake Kit -
- 12 Piston Aluminum calipers
- 400mm (16") large ventilated discs (20" wheels required)
MSRP: $3900
REAR BBK:
13 Inch Procomp Rear Big Brake Kit -
- 6 Piston Aluminum calipers
MSRP: $1850
14 Inch Procomp Rear Big Brake Kit -
MSRP: $2350
15 Inch Procomp Rear Big Brake Kit -
- 380mm (15") large ventilated discs (19" wheels required)
MSRP: $3350
16 Inch Procomp Rear Big Brake Kit -
MSRP: $4050
PM FOR BEST PRICING.
FRONT BBK:
MSRP: $1700
MSRP: $2200
MSRP: $3200
MSRP: $3900
REAR BBK:
MSRP: $1850
MSRP: $2350
MSRP: $3350
MSRP: $4050
gammamotors
44
12-31-2015 01:48 AM
bingpwr
09-04-2015 10:44 PM
